Serpent 811E Buggy Thread >
Like Tree5Likes
Old 12-06-2011 | 10:26 PM
  #961
teeforb's Avatar
Originally Posted by psionic
does that adapter fit right in to the pl6? thanks
You need the pl6 adaptation (wire). Also u have to change the wire mOde in the pl6
Call ep buddy
teeforb is offline
Old 12-07-2011 | 07:36 AM
  #962
will do. thanks
psionic is offline
Old 12-07-2011 | 01:16 PM
  #963
Frank L's Avatar
Anyone with a stock serpent 8x19 pinion that can measure the width?
Frank L is offline
Old 12-07-2011 | 04:41 PM
  #964
porkchop's Avatar
get ahold of huston on the nitro side and ask him to measure a novarossi bearing since the stock ones out of a motor
porkchop is offline
Old 12-07-2011 | 04:44 PM
  #965
porkchop's Avatar
ok all my serpent 811e racers i come with new form the man mr easton
see when you guys get me problems i get you answer
for all you people seaching begging and hoping for a lil more traction
take the set up your running and try 2 things for me
go to 3000 in your center diff.
yes i know sounds nut but think we run 5 in the center of are truggy
now go to 2/c rear link
that short on the tower down and long on the hub
give it a try and please get me feed back and i try and get you more info
porkchop is offline
Old 12-07-2011 | 05:09 PM
  #966
Can someone who is building a new serpent e buggy please measure the 8x19x6 pinion bearing with a caliper and tell me what they get for a measurement on the width. I am measuring the avid bearings at 5.93-5.95 depending on if I use the tip or the middle of the caliper.
I am swapping the v3 pinion setup into the nitro buggy and with 3 shims behind the pinion in the front it's so tight it barely turns. I took a shim out and it's better more like what I remember when I built the e bug. Thanks.
Don't forget that the V3 e-buggy pinion is 13T and the nitro car is a 10T pinion. Not sure if the tranny cases are different to allow for this or not. If not, you'll probably have to shim the diff to move the gear side farther away from the the pinion. And you'll have to go to a smaller clutch bell.
Stealth_RT is offline
Old 12-07-2011 | 05:40 PM
  #967
bigjayjay1's Avatar
Miss your call called you back so 3k in the middle
What do you mean short on the tower and long on the hub.
Thanks pork
bigjayjay1 is offline
Old 12-07-2011 | 07:13 PM
  #968
porkchop's Avatar
Thanks pork
the row with 3 holes from bottom to top is 5 4 3
so the next row form bottom to top is 1 2
so you run the 2 hole row top hole
and then the hole on the hub close to the wheel
i would try the link then the oil so you know what does what
porkchop is offline
Old 12-07-2011 | 08:42 PM
  #969
Frank L's Avatar
Case is the same case, I changed the r/p, coupler, pin retainer and boot. The only thing that's different from the e car is the avid 8x19 bearing instead of a serpent bearing. I did my homework and it's a direct swap into the nitro buggy.
Frank L is offline
Old 12-07-2011 | 10:01 PM
  #970
greg t's Avatar
Default video
can we get a video from somebody so we can see the car run
greg t is offline
Old 12-07-2011 | 10:29 PM
  #971
Frank L's Avatar
I posted 1 right after I built it. It's several pages back. Here it is again. This was the 1st time on the track and my setup has changed since this video.
http://www.youtube.com/watch?v=51UQ1...e_gdata_player
+ YouTube Video
Frank L is offline
Old 12-07-2011 | 10:41 PM
  #972
Buggy looks good Frank. Would be interesting to see an updated video with your current set up.
Honu is offline
Old 12-07-2011 | 11:35 PM
  #973
sounds like a nitro to me
so can I fit boots to the front?
thanks.
Captainlip is offline
Old 12-08-2011 | 12:02 AM
  #974
Lip, I think you will find that the front and rear axles are slightly different with the rear ones have the extra lip on it to mount the boot to. The front ones don't appear to have this.
But do you really need them? From my experience it's the rear that gets all the dirt etc and with the steering action the boots probably wouldn't last very long. I know on my DEX410 they last five minutes at most and now I just don't bother with them.
Perhaps you could fit somehting onto the drive shaft that would shield the CVJ from dirt without actually touching the wheel axle? A cut down boot for example.
Badger5 is offline
Old 12-08-2011 | 12:05 AM
  #975
good thinking.
