Tamiya F104 Pro!
#7021
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Can you post your F104 Pro setup sheet as a reference starting point? I was told I can use Kimborough spur gears but they told me I need to use some type of spacer? Anyone know where to get the spacer? Trying to find the perfect rollout as i'm new to F1 and don't want to destroy a motor.
http://www.tqrcracing.com/shop/produ...on_id=&pg_no=1
#7022
#7024
Going to bite the bullet and order a F104 Vodafone McLaren Mercedes MP4-24
What else do people recommend I order?
58475 F104 Vodafone McLaren Mercedes MP4-24
http://www.stellamodels.com.hk/produ...oducts_id=5218
54215 Spur Gear Adapter (F104)
http://www.stellamodels.com.hk/produ...oducts_id=4594
54158 F104 Aluminum Diff Housing Set
http://www.stellamodels.com.hk/produ...oducts_id=4035
Batteries - do I need a rounded LiPo or will square fit?
I need a small ESC to go with the stock can?
Thanks for your help, can't wait to get onto it!
#7026
#7027
#7028
#7029
#7030
Hello
i've got interesting problems, my suspension (two "classic" dampers, with no friction damper) works very well with my Tamya F104GT.... but i've got problems with steering.
I have on my controller EPA for steering: L: 30% R: 75%. And still everytime i turned left on the track it was too much, but on the right it was good..... i think this is not normal, do you have any suggestions? :-( P.S: i have 103GT front axle
#7031
#7032
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
hey guys, i have an f104x1, love car but am having a problem. when i try to get on throttle coming out of a turn, the car diffs out..... i've tried tightening the diff to various different degrees, including all the way locked down, where the car just loops out on throttle. the car seems to be staying flat in the corners, and does not lift the tire. but it seems that just the slightest bit of traction loss to one side causes the diff to spin.
any thoughts or ideas?
