Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 02-28-2012, 12:06 PM
  #7771
F N CUDA's Avatar
Trader Rating: 34 (100%+)
So you're retiring the car to put it in a glass case, thought you were replacing it to get a better car. Now I get it, I think.
F N CUDA is offline
Old 02-28-2012, 06:14 PM
  #7772
TryHard's Avatar
Originally Posted by Luppi Stefano
anyone has setup for 104 X1?
Rubber Asphalt
thanks
Given your in Italy, I'm gonna guess ETS and Ride Rubber tyres?
If so, try the following...
Front end;
1.5deg camber, 1mm shim under inner ball joint
Gold (medium) spring,
Standard knuckle,
Tamiya AW grease on the kingpin
Front ride-height is restricted due to the inner diameter of the wheels, just get it as low as you can, will be about 6-5.5mm
Rear end;
Shock - Oil 30wt, Red Spring, 6 turns on collar (level pod)
T-bar - High traction (softest) or medium if car is too stuck at the rear
Cross damper - Tamiya soft damper grease
Ride height - 0 axle insert (~5mm)
Aero;
I used the F60 body and front wing, with standard 104Pro rear wing in high flap angle, but if I hadn't of broken it, I'd have used a TRG Advanced wing in middle flap position.
HiH
Ed
TryHard is offline
Old 02-28-2012, 08:20 PM
  #7773
TryHard's Avatar
TryHard is offline
Old 02-29-2012, 04:00 PM
  #7774
Default tcs rules set-up
Hey guys, just wanted to know if anyone can add to set-up advice by David Jun. TCS rules in mind, with Tamiya rubber recomendations for both asphalt and carpet.
My first TCS with rubber for my 104 pro, just like some exoert advice so I can hit the track running(only a 1 day event, Can't afford to go crazy @ a new track due to time constraints)
Thanks ,Darryl
dman18t is offline
Old 02-29-2012, 04:35 PM
  #7775
F N CUDA's Avatar
Thanks ,Darryl
Just a heads up, TCS on carpet will have F1s running foams, wide and narrow.
F N CUDA is offline
Old 02-29-2012, 04:58 PM
  #7776
Suspended
Default FOAMS!!!!
which compound?
Mr. Nasty is offline
Old 02-29-2012, 05:10 PM
  #7777
theatriks's Avatar
Originally Posted by Mr. Nasty
which compound?
When we ran foam on carpet what worked for us was tamiya As in the rear always had As in the front and B fronts on standby.
theatriks is offline
Old 02-29-2012, 06:54 PM
  #7778
F N CUDA's Avatar
I don't do 180mm car on foams, never did and don't plan on it so someone else can be of better help.
However on 200mm car, 15th anniversary premounts are bomb.
F N CUDA is offline
Old 02-29-2012, 07:51 PM
  #7779
theatriks's Avatar
Are those TCS legal?
Old 02-29-2012, 09:38 PM
  #7780
F N CUDA's Avatar
104W GP uses them as an option.
F N CUDA is offline
Old 03-01-2012, 02:24 AM
  #7781
Anybody tried running their x1 without the roll damper?
I snapped mine first race yesterday and ran the next race without it before it was rained out for the night. Car actually really ran well without it.
Quite rediculous that you have to buy a whole upper deck assembly to replace the roll damper as it is the 3rd time I've heard of someone snapping theirs.
J-PaP is offline
Old 03-01-2012, 04:10 AM
  #7782
dfx
dfx's Avatar
It is an optional setup mentioned in users guide for the F104 Separated Upper Deck #54278. There was a guy running this setup successfully (last summer outdoors).
Or go for Alum Roll Damper Set #54342. It should be out now.
Have anyone compared carbon vs. FRP lower deck for the outdoor foam racing?
dfx is offline
Old 03-01-2012, 10:35 AM
  #7783
Luppi Stefano's Avatar
Front end;
Standard knuckle,
Rear end;
Aero;
HiH
Ed
many thanks!
Luppi Stefano is offline
Old 03-01-2012, 03:33 PM
  #7784
rays_tt's Avatar
Trader Rating: 26 (100%+)
Hi guys, I just finished building my f104 pro and was having troubles getting my batteries to fit.
I have 2 types as show in the pictures below.
The IP battery doesnt even slot in at all and the yeah racing fits however I cant fit the small battery secure piece as theres not enough room up top, any suggestions or am I not using the correct type of batts?
cheers
rays_tt is offline
Old 03-01-2012, 04:10 PM
  #7785
Default f104 pro TCS SET-UP
I'm in Canada, and our TCS races are rubber only carpet or asphalt, that's why I was asking if anyone would like to add to David Jun's guide with thier own experience with Tamiya rubber.
Any tricks or tips would be appreciated.
dman18t is offline
