Tamiya F104 Pro!
#7176
Not sure why we have gotten results with the Tamiya tires. The carpet is older, not sure how old. The tires we are using have a few heat cycles on pavement put through them, and then onto the carpet.
I ordered a set of the Shimizu tires to try at our next point race. After all the reviews I've seen, I had to try them.
#7177
#7178
#7179
Hello guys, so I started assembly on the X1 and all went smooth, I just don't like quite much the new tamiya material used for the chassis and top deck... I was wondering if using the long carbon fiber top deck bring any advantage/disadvantage runing on shimizu tires on asphalt? No plans on a standard X1 short top deck in carbon fiber?
I may consider even installing the carbon chasis if no disadvantage will take place.
Oscar
Oscar
#7180
Oscar
Oscar
May get away with the stiffer setup on carpet tho.
#7181
I noticed while prototype testing that a flexible chassis created more steering
I think Tamiya uses the fiberglass to add a little steering, make the car heavier (more stable) and save on some $$$. Fiberglass is 1/4 the cost of good carbon fiber....
#7182
My all fiber glass F103 is an absolute monster of a car in just about any situation i can drive the nuts off it.
My EXO104 requires a finer touch but it's still a nice car which puts in great lap times when you're on it.. I guess kinda like Mike R has said before the older Exotek F104 is quite agressive and it takes a lot of concentration to keep it in check.
I do think a lot of people see Fiber glass as cheap instead of an alternative to Carbon.
#7183
Trader Rating: 27 (100%+)
I was told by someone in Japan that that would happen. I think it is because the front is lighter and narrower then the battery end so unsprung weight at the front naturally creates more responsiveness at that end.
#7184
#7185
I still can't get my EXO104 as dialed as my F103, I know the setup is there it's like you said the stiffer chassis responds to changes better so my lack of setup knowledge/experience makes setting up the EXO104 harder.
I'm convinced the setup to make the EXO104 drive as well is in there just it's on more of a fine 'point' than the F103.
Totally to do with chassis stiffness too.
