Tamiya F104 Pro!
#6271
Hello F1 racers.
2011 IIC F1 Spec tires & wheels are back in stock from RIDE.
Spec Tires:
- No. 24005: F-1 Rubber Tire, Front Tire, H1/Compound/Medium ---> for F-1/Tamiya & F-Ten/HPI
- No. 24007: F-1 Rubber Tire, Rear Tire, H1/Compound/Medium ---> for F-1/Tamiya & F-Ten/HPI
Rims:
- No. 25002: F-Ten Front Wheel, Black Luster ---> for F-Ten/HPI
- No. 25003: F-Ten Rear Wheel, Black Luster ---> for F-Ten/HPI
- No. 25004: F-104 Front Wheel, Black Luster ---> for F-104/Tamiya
- No. 25005: F-104 Rear Wheel, Black Luster ---> for F-104/Tamiya
Click Here to check out the restocked items.
FYI, Thanks.
Spec Tires:
Rims:
.jpg)
FYI, Thanks.
#6272
Some advice please:
I m still new to rc and we have another rc race this weekend however I am struggling with getting my car turned in.
I usually run Tamiya Foams B on the front with F103 on the rear however we cannot get hold of Type B in thailand at the moment so I am stuck with A's on the front and after 3 laps the car will just not turn. I have put grip only on the front(half the front tire) and this helps for about 5 laps but then it just wont turn.
Any advice/tricks would be appreciated.
I am running a F104 with Exotek , 10.5T Hobbywing motor.
Many Thanks
Many Thanks
#6273
Some advice please:
Many Thanks
Many Thanks
RCF1 blog
#6274
Some advice please:
Many Thanks
Many Thanks
A foam is not going to work if you are on asphalt. 1/10 pan car donuts will work, or try one of the HK shops, who should have tires.
#6275
Some advice please:
Many Thanks
Many Thanks
#6276
That is going to depend on the asphalt and if it is treated or not. When I first started racing pan cars on asphalt foam tires worked very well but parking lots we went to after it didn't work without some sort of treatment for added grip. It seems to be related to the sealant used or not used if foam will work or not.
#6277
I got it of Ebay dont know if any body saw it? F60 with Alloy upgrades? (had 2 get 2nd hand as the mrs would kill me an i can make out ive had it for years in the loft lol) Its on foams at the moment and i want rubber wheels an tyres for it! Any surgestions?
#6278
You could also try raising the rear ride height a bit to get more weight transfer on the front tires.
Also sauce the entire tire.
#6279
#6280
I was wondering why you said foam was no good on asphalt.
Now I get what you're sayin, "A" foam is no good on asphalt.
Now, my 103 with the right foam on asphalt will destroy the same car with rubber.
The 104 on either foam or asphalt isn't even in the same league so I wouldn't even try to catch the 103.
Now if you have to run the F104, first off let me say I'm very sorry
BUT if you do have to run it, the F103 front end and the F103 tires front and back will make it almost feel like a race car and that is about as close as you are gonna get.
#6281
Here is 1 F104W who drives almost the same as my F103.
And this said after just 2 hours of getting to know the car
40sh front and 30sh on the rear.
Black springs on the front,red spring on the center shock with 300 Tamiya oil in the shock.
Front a bit lower then the rear.
The super soft T-bar is a bit up to the chassis and this works fine.
The single middle screw is gone and a glued a shock foam kussing between the T-bar and the rear battery mount to keep it almost level to the chassis.
regards Roy
regards Roy
#6282
For a guy that hates the 104 as much as you do, you sure have a good track record with it. My 103 is a rocket compared with my 104, but I figure the more time I spend with the 104, the faster I will get
#6283
Can you get wet weather rubber tires?
Also thinking maybe doin a Mercedes using a brawn body but the listing has been taken of eBay! Any 1 know where you could get the body or stickers? But I do like the new Renault Lotus! Help lol
#6285
OK I have a F104 pro. I have a Xrs Novak esc and a silver can motor in it now. would you A) keep that in the car and just run it with a 2s lipo or B) Put in a brand new brushless SpeedPassion V3.0 w/ 21.5R and run the 2s lipo ??? any help would be good. I will post pics of the bodies and wing sets for sale soon.
