Tekin Rx8 Gen3 Thread >
Like Tree85Likes
Old 11-08-2017 | 06:29 PM
  #121
Would it be unheard of to run this in a Monster Truck (MT410)? I need the small footprint this ESC provides because of the Truggy length motor I plan on using. I have been running the gen 2 in a SCT410 for a few years and it has been rock solid.
rydaddy is offline
Old 11-08-2017 | 07:54 PM
  #122
EbbTide's Avatar
It is the ideal ESC for that truck actually it should handle whatever you throw at it short of a 1/5 scale
EbbTide is offline
Old 11-10-2017 | 05:55 PM
  #123
platgof's Avatar
This esc rocks. I had a blast last week running it.
platgof is offline
Old 11-19-2017 | 08:51 AM
  #124
Gizmatron's Avatar
Is there an upgrade program for these? I have a couple of gen 1 going strong but one has finally had a post come loose.. can I get it repaired/upgarded to gen3?
Gizmatron is offline
Old 11-19-2017 | 03:31 PM
  #125
mkl
I believe you can send it to Tekin and for a fee, upgrade to a Gen 3. I did that with a Gen 2. Well worth it.
mkl is offline
Old 11-19-2017 | 03:41 PM
  #126
Gizmatron's Avatar
That's my understanding but the link randy posted previously doesn't quote prices i can see.. also is there any DISADVANTAGE to using the RX4 over the RX8 , heavier case, splashproof, same power handling? whats the RX8 got that makes it more expensive? or better?
Old 11-19-2017 | 03:43 PM
  #127
EbbTide's Avatar
It's going to be around $125 + shipping when you send in your ESC for an upgrade.
EbbTide is offline
Old 11-21-2017 | 06:36 PM
  #128
platgof's Avatar
The Gen 3 is amazing. Be sure to mount it with shoo goo.
platgof is offline
Old 11-22-2017 | 04:01 PM
  #129
B3nno810's Avatar
Originally Posted by Ggrant
Hi guys is this esc for off-road or on road ? I like tekin products but I'm just wondering about this one what's it's primarily built for .
Not sure about the Gen 3. But the Gen 2 was an offroad only esc. The onroad boys tried them, and they blew smoke pretty quickly as they couldnt handle the constant high power draw that 1/8 onroad puts on them.
B3nno810 is offline
Old 11-22-2017 | 04:10 PM
  #130
Curious which ESCs will handle 1/8 onroad?
rydaddy is offline
Old 11-29-2017 | 05:24 PM
  #131
Trying to calibrate with Hitec Radio(Lynx) IT calibrates fine but then runs in reverse order(pull trigger, car goes in reverse). I reverse the operation on the throttle channel of the radio and it wont calibrate. Any ideas?
underway is offline
Old 11-29-2017 | 10:03 PM
  #132
You either are using a non sensored motor, or you have your motor leads wrong. Make sure a goes to a b to b and c to c
faqcya is offline
Old 11-30-2017 | 05:40 AM
  #133
I got it figured,have to run the motor in mode 7due to the way it mounts in the car. All leads are soldered correctly and using a tekin motor.
underway is offline
Old 01-15-2018 | 03:44 PM
  #134
I've got two of these (one in an 1/8 ebuggy and the other in an 1/8 etruggy). I have to say I am super impressed with them. The buggy runs a 2000kv tekin truggy motor on 4s and the truggy is running a 1350kv tekin truggy motor - both run great. I really love the data logging capabilities. I also sprung for the bluetooth hotwire and have one on each car. I love being able to make adjustments with my smart phone.
Also - the buggy I have found doesn't need a cooling fan. The ESC at the end of a 10 minute run is sitting at 105ish degrees. The truggy runs just a few degrees warmer (expected because it's bigger and heavier). Simply awesome stuff.
Tekin Prez likes this.
rock-rod is offline
Old 01-16-2018 | 01:46 AM
  #135
shannow's Avatar
I am interested in the logging data ability via HW, does anybody knows if I get the gen3 Rx8 and buy a Hotwire 2.0 will I be able to view the data log on a cell phone ? Or is it exclusively usable on PC ?
shannow is offline
