New Spektrum Radio DX6R
#1501
New to this remote, any base line setting for indoor 1/10 car?
#1502
Takes a long time to get a reply in this forum!?
I've since bought a SRS6000 (AVC) receiver and the TM1500 telemetry module. Just waiting on it to arrive.
The AVC should be a handy feature to have with my modded X-Maxx when it's motoring at 70mph+ off road.
The traxxas TQi variant worked quite well at @50% setting so I'm hoping AVC will be even better as it's a lot more customizable.
#1504
I’ve been playing around with the ABS tonight (on a wet and slippery road) and it works better than I thought it would, quite a usual feature to have on.
Have to say so far no complaints with the DX6R, love being able to tune it with the screen. Makes things a lot easier!
Also it’s very comfortable in the hand too.
#1506
Yeah I know what you mean about it feeling 'connected', big improvement over my stock Traxxas unit.
I'm using the SR6000T at the moment (whilst waiting for the SRS6000 to arrive) and it feels a lot more controllable with the DX6R.
With the added AVC the SRS6000 has will make things even easier at high speed which is what I want it for.
#1507
Is their a way to calibrate each model? One of my models on the "monitor" page steering is -17 and throttle is -12
#1508
The monitor screen in your true output of the system. If your neutral shows -17 and -12, it is typically due to either your sub trim or trim being adjusted. that is all.
#1509
Here is 2 screen shots, 2 different models
#1510
#1511
NOPE But after playing with the transmitter a little I did find the "area" to re-calibrate throttle, steering and knob. I was successful in doing so now they are 0.
#1512
Hi there,
I've just installed my SRS6000 (AVC) receiver and the TM1500 telemetry module.
I bound the two of them together.
I went through the process of setting up everything on the transmitter, selected SRS6000 in the list of receivers (although there is no option for SRS6000 with telemetry).
I completed the setup process but I don't have the telemetry it doesn't appear on the dashboard.
AVC option is there in the settings, but no telemetry.
If set up the SRS6000 receiver as a SR6000T receiver from the set up list then telemetry shows up on the dashboard again but there is no settings option for AVC!
I want to have both telemetry showing up on the dashboard AND have AVC in the settings as that was the whole point of buying the SRS6000 (AVC) receiver and the TM1500 telemetry module.
Does the raceware app need updating or something, I'm running the latest 2.01.01.
Really hoping for a answer ASAP as I need to decide whether or not to keep the SRS6000 and TM1500.
#1513
Need some help, just bought a brand new Dx6r. It’s the newer radio with the new race ware. First thing first I can’t get it to turn on. Screen won’t do anything. Figured the battery was dead. So I charged it and when on the charger it reads the battery and the battery level thing on the front of the radio turns orange. Says it’s basiclly charged and I’m holding down the power button like the manual says but nothing powers on. Suggestions?
#1514
If you contact Horizon support, they will get you fixed up ASAP.
#1515
Hi there,
