Trinity/Revtech 24k
Old 12-23-2015 | 08:21 AM
  #106
Motorman007's Avatar
Just some info that was given to me from Team T
The goal is to keep the motor under 180.
Below that the lower the temperature, the better the motor will finish the race (less fade).
As long as keep the motor under 180 no damage will happen.
For example, in hot summer in a touring car with track temps in the 150 range, motor temp can get to 180 easily so a fan is a must. Racing indoor offroad depending on the layout and class, our team guys run the motor 130-165.
In all 1 cell applications we try to keep the motor below 150. Anything above that fades hard at the end of a run and there is not enough voltage to push the motor.
I hope this helps
Mark
TRINCORP LLC
Motorman007 is offline
Old 12-23-2015 | 08:52 AM
  #107
Default 24K
Originally Posted by crisis641
So looking for a little advice on timing and gearing for the 24ko for people who are running them in either 17.5 Stadium Truck or 17.5 buggy. I tried mine for the first time last night in Stadium truck and it seemed like a dog. Ran timing from 48 to 53 degrees and geared anywhere from 72/29 to 72/32. It seemed the 'fastest' at 53 degrees at 72/32 but it was a little hot (150's) at the end of a heat race so I started backing some things off.
I've got a D4 1S that is very fast in my buggy so I kind of started around the same settings on this 24ko.
That temp is good a little hotter wouldn't hurt none! Not sure if your indoors or out and the outside temp but my motor temps of my motor's run around 170-175* my track is short and technical indoors temp around 70-75*. Winter time here in Colorado. My gearing is around 6.19:1 (72/30) on my KF2 6 minute run's no fan and 30* timing.
MelKF2 is offline
Old 12-23-2015 | 08:53 AM
  #108
Originally Posted by skinned
how come they don't put the name "trinity" on the 24k?...don't they produce it?
It's Revtech.
Andy Koback is offline
Old 12-24-2015 | 08:43 PM
  #109
Jpdanger's Avatar
I hate to say it, but I think you bought the wrong motor. You should be using the 24K. I use the 24k in my 2wd, ST, and SCT. I had the 24ko and promptly replaced it with the regular 24k. I thought the same thing that the motor was a dog. I couldn't gear nor time it high enough to keep up with my D41s. There was also some very large noticeable power fade around the four minute mark.
I'm loving the 24k and even upgraded my buggy and truck to the certified version of the 24k. It's a beast of a motor! I also run a standard 24k 13.5 in SCT and I get a lot of people question the motor I use once they see how fast it is.
The 24k is leaps and bounds faster than the previous D4.
Jpdanger is offline
Old 12-25-2015 | 04:34 PM
  #110
8ight-e's Avatar
I had better luck w/ the ko in 13.5 SCT... the k was lacking in power before the end of a race.. the ko is strong thru the entire race. They use the same rotor the blank is different, how it handles heat.. the KO can take more heat w/o washing. All rotors are not created equal nor motors... and tbh my maxilla 17.5 which also uses the same rotor is faster and better than the 17.5k I tried. Again not all motors/rotors are created equal so from motor to motor person to person results can very.
8ight-e is offline
Old 12-26-2015 | 09:46 PM
  #111
skinned's Avatar
whats the problem with running a 24k outdoors?......with the large openings....i heard that it is not recommened...i think thats a bunch of bs....anybody else hear anything about this?
skinned is offline
Old 12-26-2015 | 09:48 PM
  #112
likea45's Avatar
Nope. I ran it outside with no issues.
likea45 is offline
Old 12-28-2015 | 09:22 AM
  #113
Mudcat981's Avatar
You are correct this is BS.
Mudcat981 is offline
Old 12-29-2015 | 08:23 AM
  #114
tazfam2's Avatar
What is the best motor for a sc5m the 24k or the Ko in 17.5 and what gearing. Thanks for any help
tazfam2 is offline
Old 12-29-2015 | 09:31 AM
  #115
DriveItLikeYSIT's Avatar
You wanna get the KO for a Sct or Stadium truck. I'm not sure about AE gearing but I use 75 / 23 w/ 58 degree on my 22sct..
DriveItLikeYSIT is offline
Old 12-29-2015 | 07:01 PM
  #116
Default Timing
I don't run either but that timing is way to much! Trinity recommends no more than 50*
MelKF2 is offline
Old 12-29-2015 | 07:19 PM
  #117
The timing on my motor was recommend by a trinity team driver. I haven't had an issue with overheating or motor fading..
Old 12-29-2015 | 08:05 PM
  #118
Mine even came from the factory at over 50* timing. But no clogging and didn't overheat. I think people should so more testing and find out what works for them.
Chris Brown is offline
Old 12-29-2015 | 08:31 PM
  #119
all my hand built certified motors have came with timing over 50. A couple at 60.
Franzchise is offline
Old 12-30-2015 | 09:00 AM
  #120
Mudcat981's Avatar
Who told you that? I have several Trinity D4s and all are tuned to 50 or above. I have returned 2 to Trinity for repair and they both came back at 55*. I talked to Kevin Abbott from Trinity about my motors and he stated the D4 1S came alive at 50 and above.
I have tuned my motors for maximum rpm/kv vs. amp draw and they all come at around 50+. They never get hot (120-140 degrees after 10 min run)
You may think I am attacking you I am not, but if you refer to the D4 1S and 17.5 motor strings you will see what I am talking about.
I have a 24k and I have yet to place it on my motor checker but the end bell is set to 55* from Trinity.
