iCharger 406 DUO Charger
#451
You all can just make your own discharger for under 20.00 or maybe free and do your hair while discharging
http://www.rcgroups.com/forums/showt...ght=hair+dryer
#452
You guys are gonna hurt somebody. s*** happens
But since everyone needs that one tenth advantage charge your stuff away from people and in a good lipo sack
#454
Both is quite unnecessary for beginners or people who don't drive very consistent lap times.
#455
Without a resistor bank around 10 amps seems to be the max my 406 will discharge. Today several guys told me you can program the icharger to go up to around 17-20amps without a resistor bank. We were racing so there was 't time to start an icharger class.
Does abyone know how? I know the menu system really well, but nothing pushes my 2s orion ultra carbon 4500 to more than 10.78 discharge amps?
#456
Another possibility is a 1S pack like used in 1/12 onroad, those can discharge higher since the voltage is lower than a 2S. Conversely 4S would be lower amps.
#457
I just had a thought about how to force the icharger to discharge higher. I heard this a while back but forgot... Is there a way to make the icharger think my 4500mah pack is actually say a 10,000mah pack or some really high mah number - that may do the trick... But I'm not going to bother. My resistor bank will be here before my next race.
#458
#459
Nope. It has nothing to do with the pack's capacity. As Dave H told you, you are limited to 80W (or 140W in sync mode) internal discharge rate - for more than that you need to have some kind of load (resistors, light bulb, another battery) on the other channel - or use an automotive lead acid car battery as power supply. There is no other way.
#460
Then just reuse the energy and pass it back for charging the race pack. Be a hybrid setup in a way. Obviously it would take some management of the charge state of the pack(s) used, but since lipos charge and discharge fairly efficiently it shouldn't be that hard. The charger can monitor it, and easily top it off a little if needed at some point.
#461
Most modern batteries, say right on the package :3C Charge current, some even have higher.
#462
I think a battery on the other channel is an under used method. Instead of using a resistor that dissipates energy and generates a lot of heat that must be dealt with, just use a couple to few old packs in parallel to convert the energy chemically. With little heat.
#463
#464
Is there a way to charge a receiver pack with just the balance connector?
