Like Tree2Likes
Xpert Servos
Old 03-25-2015 | 01:31 PM
  #121
Originally Posted by Darrin70
I am looking to replace them in my 1/10 offroad also, but just abit costly when you race too many classes, 2wd stock 2&4wd mod rear motor, mid motor etc!!! lol
Yeah they are a bit more than say Savox, but so far I am loving the Xpert Servos. Put the PI-3431 in my PRS1 and it is great. Super smooth and no more receiver cap or that annoying buzz.
After replacing 2 gear sets in the last year in my Savox 1258 I put the SI-4431 one in my EB48 and have to say I am loving that one as well. More torque and more responsive.
Can't go wrong in my opinion. Also I will support the brands that support racing here in the Northwest. Xpert is sponsoring the NCT series out here!
New customers can use coupon code 10percent on TQhobby.com. The links above
mrniss99 is offline
Old 03-25-2015 | 02:04 PM
  #122
Cain's Avatar
Tech Legend
for the impression I was able to get of the servo I had before selling the warranty replacement, the physical build quality looked good and off of the 6V battery pack did some testing with on it, it seemed to be quite powerful. It also had a very smooth feel to it. This was a WR7701 servo.
The only comment I would make and this would go for any electronics, if you notice anything odd happening with your system, stop and contact the manufacturer right away. Do not believe it is something "one off". This can be an expensive and time consuming lesson to learn.
Through it all Nick provided great customer service, a real bright spot.
Cain is offline
Old 03-26-2015 | 11:46 PM
  #123
Hitokiri_2000's Avatar
That WR-7701 has monster torque, plus it can handle up to 8.4V, so deffo NOT a bad piece of kit to have in any model. I just ordered a WR-6601 the other day and that as well can handle up to 8.4V, but I'll only put 7.4V into it, since that's the maximum voltage the onboard BEC output can be for a Tekin RX8 ESC as I'm sure tons of you guys know already.
Granted, the WR-6601 and WR-7701 are slower than the WR-4401. Not sure if it really mean that much for 1/8 scale buggies, if they are a fraction slower or not.
Not sure what I'll do with the Savöx SC-1258TG i'll be taking out of my DEX408 buggy, if I should sell it, or put it in one of my other models.
I'll probably put it into my Compagnucci 1/8 gasoline model. I won't hear the noise once that baby if fired up. Plus I have wanted to get a servo with decent torque and speed for that model for a good while now, so seems to be the perfect time change the excisting servo.
Hitokiri_2000 is offline
Old 03-27-2015 | 07:23 AM
  #124
Cain's Avatar
Tech Legend
Yeah my original plan was to use it in a solid axle truck for "mud / snow" running hence why I wanted monster torque as well as waterproof. The 6601 model though interested me as well and i was considering that for my tekno et48 which would have been the next model to be upgraded to Xpert servos if things had worked out better with the WR7701.
But from what I have seen, others are having a blast with them and they look to be good. Just bad luck I guess. Just wish it wasn't $100 over the cost of the servo itself to find out.
one thing I would love to see in servos in general would be some form of a plug and play servo wire so you can lengthen and shorten with a quick swap.
Cain is offline
Old 03-27-2015 | 08:18 AM
  #125
They showed the RS series servos with that feature a while ago but I haven't heard anything about them recently.
http://www.liverc.com/news/new_produ..._new_feature!/
kawi650 is offline
Old 03-27-2015 | 08:31 AM
  #126
Cain's Avatar
Tech Legend
that's really cool. Be curious on fitment if they go with that setup on say a Tekno vehicle based on how they servo is mounted.
But still very cool.
Cain is offline
Old 03-27-2015 | 11:59 AM
  #127
Cain
Wouldn't it be easier to just make the servo wires your self? You could cut the wire on the servo 2 inches from the servo and then put a plug on it and make what ever length servo extender you would require for the model in question. I make my own servo extenders and it's easy with the right tools.
Hansen Hobbies have all the things you would need to get started like wire, plugs, pins and tools such as wire cutters and the special pliers needed for crimping if you don't want to mess with a soldering iron.
http://www.hansenhobbies.com/products/connectors/
Old 03-27-2015 | 12:06 PM
  #128
Cain's Avatar
Tech Legend
Nothing is as easy as plug and play
Cain is offline
Old 03-27-2015 | 12:50 PM
  #129
I make my own Plug N' Play hehe
Old 03-27-2015 | 12:58 PM
  #130
Cain's Avatar
Tech Legend
yeah I think the big advantage to setup like this is if you damage a servo wire in a pinch you can quickly change it out.
Cain is offline
Old 03-27-2015 | 01:16 PM
  #131
True and that's why it's nice to be able make what ever length servo wire you need.
Old 03-29-2015 | 11:31 AM
  #132
Shown below: I Just installed an Xpert WR-6601 servo in my Durango DEX408 V1 buggy
Shown below: Making sure it get's a constant flow of maximum juice at 8.4V I also installed a Castle Creations 10Amp BEC.
Shown below: Though maybe difficult to see properly, are some of my own servo extension cables. Going into the RX the connectors to the external BEC, ESC and servo is sort of hovering above the servo it self. Maybe even harder to see, is the extender for the ESC you can see only the black and white cables is used as the red needs to be inactive for the external BEC to do it's job properly. So if you look closely at the first plug going into the RX you will see what looks like a hole where the red wire would go into the plug.
Shown below: Is the majority of tools I use to make my own servo extension cables.
Old 04-08-2015 | 05:19 AM
  #133
mkl
I am considering buying a 7701 servo for a Wraith. For those that have one, what have your experiences been?
Cain- I saw some posts of yours, do you still have your servo? did your issue get taken care of?
Any info would be great.
mkl is offline
Old 04-08-2015 | 05:31 AM
  #134
If you do decide to purchase the 7701 you can get it you can use coupon code 10percent for 10% off here
mrniss99 is offline
Old 04-08-2015 | 06:37 AM
  #135
Cain's Avatar
Tech Legend
I received a NIB servo in return, but I didn't feel comfortable using it so I sold it to recoup some of my losses due to having to replace an out of warranty ESC it apparently killed in addition to several replacements it killed as well. I can't imagine what would have happened cost wise if I had tried hooking up to other ESCs I had here that are out of warranty to but work fine.
I do believe i probably had a one off issue however, but what I wanted to use the servo for (winter snow running in a monster truck) had the time to use it pass. So I sold it to someone else who could use get more use out of it.
Maybe down the road I'll give it a look again as some of the other servos have specs I like, but I will make sure I only do that with an esc still under warranty.
Cain is offline
