Xpert Servos
#241
I've never raced before. I'm setting up a RC10 B6 to try carpet racing and am trying to decide on a ESC, based somewhat on the BEC. One Hobbywing ESC I want to use has a 2A linear BEC, and the other has a 3A switch-mode. Both ESCs have cooling fans. Obviously the 3A switch-mode is better, but I'm wondering if I can get by with the 2A linear.
I'd like to run an Xpert servo, but have some questions about their power demands. I'm leaning towards the PI-3431 servo; which I think will be more than adequate. Will that run fine with the 6v 2A linear BEC? The PI-3402 is about 50% stronger. Do I really need the extra torque, and if so, would the 3A switch-mode BEC be required for the PI-3402, or would a 2A linear still power that and a cooling fan?
Thanks for your time!
#242
#243
Thank you for the reply. I actually already got the PI-3431, because I was afraid about the amp draw. It turns out I didn't need to be. I'm used to coreless servos - brushless are MUCH more efficient. At 6v the peak amp draw was under an amp!! The range for me was between .20 amps and .97. Really, really impressive. I'm looking forward to getting this on a track. I'll look into Xpert for RC heli servos, too. I hadn't heard of them before doing research for my new 2WD buggy..
#244
2Likes
