Xpert Servos
#91
WailinOnYa - from your description that would seem more connection or radio/receiver related. Servo and speed controls are passive units - they are going to do what they are told or nothing at all.
If you have the Viper ProGuage, it has a function that lets you test the signal coming out of your radio to see that the "throw" of the signal is currect - you can read more info on it here -- https://www.facebook.com/notes/viper...38780019525886
Cain - I was told (I'm in NY for the holidays, not that WA office), that one of the techs was looking at your servo today, will update you when I know more...
#92
Sounds good. I got in the proguage and other items I ordered, very fast shipping!
Here are some pics for those interested, servo in comparison is a Hitec 7955TG I believe.
#94
3401 - all aluminum case and supports top and bottom.
Little heavier weight, more durable case. The more durable case is not so much because we worry about the case breaking - its because the case can flex in an impact, which could move the support pins and cause a stripped gear. Not that it happens a lot - its just the extra security is what your going for with that model.
#98
The Xpert 4431 would be awesome in 4wd buggy and either 2 or 4wd corr truck. Price is great for a servo with it's specs too. I'm nobody special (unless you ask my mommy) but that's what I'd buy for any of those.
#99
Is that the 4000 series? Amain has that one and part code has 4431 in it
#100
#101
Hello guys, can some one explain the plastic and screws that comes with the servo and some plastic adapters kind of thing? it was my first time buying a couple of servos for my xray xb8 and really dont know if I have to use something in the bag for the build or i just want to know what is everything just in case, just want to learn more about the hobby and its parts.
the servos are SI-LV 4531 and SI-LV4431 here is an image of the things that came with, thanks in advance for any guidelines.
#102
Pretty sure I answered the question on Facebook for you - but those are misc arms just in case they are needed. Most of the time a car company will put the correct arms you need in their kit. Follow the instructions there for set up.
Be glad to answer any other questions about Xpert servos here or on Facebook.
#104
#105
The Lee Martin editions come with short leads- by design. The standard units are longer. If you have a standard unit with a shorter wire it was probably done by the previous owner.
2Likes
