DX4R Pro
#781
Are you selecting the 5.5ms frame rate BEFORE you bind?
Just for you I pulled out my B6 and bound a sr3520 to test. Selected 5.5ms frame rate, Bound the Rx without a servo plugged in. No issues.
Bound again with a Spektrum 6040 servo plugged into the Rx, again no issues. Radio holds the 5.5ms frame rate on DMS2.
Bound back to my SR2000 Rx, screen switched to DSRM and 5.5ms frame rate.
Long story short, make sure you select the frame rate before binding.
Hope that helps...?
Hope that helps...?
I've tried it with just the ESC plugged into the receiver and with the servo and PT plugged in. Same results both ways.
#783
The most recent firmware update disabled support for older receivers. The one you have bought might have been upgraded to that version.
#784
From Spektrum:
"This version will disable all RF protocols except DSMR and DSM2-16.5ms"
#787
Hey guys i have a spektrum dx4r transmitter and the little orange led light on the aerial doesnt go on anymore. What does this mean? I have tried binding it to a couple of my receivers aswell as just turning the controller on and still nothing.
#790
I just checked and mine comes on within a second of the power up. Right when it says Spektrun in start up. Id give Horizon a call to see if they can help. Of course make sure youve done the easy stuff first like changing batts, etc..
#791
The best batteries to use in thus or any other transmitter are the Panasonic eneloops. Not the pro ones but the regular white ones. They rate much better than the pros. These are what all the pro photographers use in their flashes. There has been extensive testing on batteries to determine the best ones and the standard eneloops come out on top. They hold charge the longest, recycle the fastest, and can be recharged the most number of times. Real good prices on amazon with the great charger that comes with them. If you look into it these batteries are real impressive.camera flashes are high draw devices and their recycle time is directly related to the quality and type of battery you use.that is how I found out about them.
#793
#794
The update apparently enables telemetry support for the SR4000T and SR6000T, so if you do not need that there is apparently no reason to upgrade the firmware.
#795
NIZN batteries are the way to go, nothing is even close. You have to use a NIZN charger for them. I have seen 4 batteries and charger for less than $20. I also have a spare set of 4 when needed. I put a lipo in my DX3S and it is still showing 7.9 volts 3 months later. That is very impressive and the battery cost like $12. I had to mod the radio and the battery. Soldering a Deans connector onto a battery makes me every nervous to say the least, I took lots of time doing it.
1Likes
