Like Tree1Likes
DX4R Pro
Old 02-15-2016 | 04:37 PM
  #676
monkeyracing's Avatar
R/C Tech Elite Member
Good option! Thanks.
monkeyracing is offline
Old 02-16-2016 | 06:43 PM
  #677
platgof's Avatar
You can now get 9800 mah 3.7 volt 18650 batteries. These would last a very long time, and they are cheap. I can get 4 ea. and a charger for $13, shipped. I really wish all radios had these as std.
platgof is offline
Old 02-16-2016 | 06:44 PM
  #678
Kremzeek's Avatar
Is there a secret to getting this thing to bind with SR301 receivers? I tried increasing the frame rate but it didn't work.
Kremzeek is offline
Old 02-16-2016 | 07:09 PM
  #679
They won't bind with DSM "1" receivers anymore. Makes a lot of my gear obsolete!
Thanks for the battery tip, platgof. I think I've got a few of those hanging around.
Old 02-18-2016 | 02:19 PM
  #680
Default Any Issues with this Transmitter?
Looking at upgrading from a DX2s - have not broken a steering spring with my DX2s, but seeing quite a few posts here that the tension spring has been breaking with the DX4r.
maybe it was a few bad springs in the bunch? I did have one break in a RTR spektrum transmitter many years ago.
I like the feel of the DX4r compared to the Airtronics MT4s (too small steering wheel and no drop down - which feels nice).
thanks.
hsp-sandiego is offline
Old 02-18-2016 | 02:48 PM
  #681
Seems to be a common problem across the board with Spektrum radios. There's a Futaba heli part that fits the bill, is cheap, but is a little stronger than the Spektrum items. Futm3640
Old 02-18-2016 | 02:58 PM
  #682
Originally Posted by monkeyracing
Seems to be a common problem across the board with Spektrum radios. There's a Futaba helix part that fits the bill, is cheap, but is a little stronger than the Spektrum items. Futm3640
great, thanks for the Part# - monkey racing!
Old 02-19-2016 | 12:42 PM
  #683
Got the Yeah Racing steering wheel. Supposed to fit Spektrum, but it's going to take some work to make that happen. The adapter is about 0.5mm too small on the inside. Shaving that out cleanly will be tricky.
Old 02-20-2016 | 04:48 PM
  #684
platgof's Avatar
I have been using the NIZN batteries since April 2014, and absolutely the best thing I ever did for this radio. Almost 2 years and no issues. I use 2 sets as I swap them out, so one set can rest after use. It must be working! I usually recharge at 6.4 volts, imagine that.
platgof is offline
Old 02-21-2016 | 06:35 PM
  #685
Lexicus's Avatar
Yeah don't let them go low - they will dump quick! I had it happen, the alarm on the radio goes off and it's not usable. Swapping between sets is a great idea.
Lexicus is offline
Old 02-21-2016 | 08:30 PM
  #686
Swapping how often? Every heat? Each race day?
Old 02-22-2016 | 07:59 AM
  #687
Lexicus's Avatar
Each time you go to the track should be plenty. I ran my first set for a few weeks before I saw them dump, I think it went from around 5.5v to 3.3v during a heat.
Lexicus is offline
Old 02-22-2016 | 06:22 PM
  #688
platgof's Avatar
These last for two days of racing easily. I swap to make it very easy on the batteries, and I do the same thing for my rc cars. When I buy batteries, I always buy in sets of two. When the radio gets near 6.4 volts, I swap them. I am getting two years of high performance use for around $30 and still going strong. I think they are reading around 6.9 volts now when charged, but read 7.1 when new.
platgof is offline
Old 02-23-2016 | 04:15 AM
  #689
jmcelroy42's Avatar
I run my ni-zn batteries for like 6 weeks of racing before they get to 6.4 or so and I change them out.
jmcelroy42 is offline
Old 02-23-2016 | 08:39 AM
  #690
Yosh70's Avatar
Really
Yosh70 is offline
