Like Tree95Likes
Tekin RSX Thread
Old 03-24-2017 | 03:06 PM
  #1261
Originally Posted by Randy_Pike
That number is a value we use to determine the throttle calibration point. Your model maybe a little different between the two. For example if you calibrate at 100% on your epa's vs 140 or 150% on some radios will show a different value in the data log.
As long as you're getting WOT or wide open throttle which you can verify with your ESC's LED tree showing all LED's ramping up and flashing you're good to go.
ok, sounds reasonable. It was the very slight fluctuation I was worried about.
On the ESC it does show the lights ramp up on throttle and does show full blinky at full.
I was thinking the datalogging was showing that the throttle was very slightly flickering from 100% to like 99%. I've set the endpoints on the esc to the radio several times with the same result.
lawton70 is offline
Old 03-24-2017 | 09:45 PM
  #1262
I just updated my RSXs to v258. No issues! Thanks Tekin!!!
rbk1115 is offline
Old 04-02-2017 | 04:23 PM
  #1263
I need a capacitor for my RSX. Would radio shack have what I need? Also, was would I go in asking for? Lol
Monster Mudder is offline
Old 04-03-2017 | 05:24 AM
  #1264
Unless they have Low ESR capacitors, I wouldn't get any from there. If they do, then look for one rated for 16 to 20 volts with a microfarad (mF) rating of 330 or greater.
Krio is offline
Old 04-03-2017 | 05:59 AM
  #1265
Hey all... I'm pretty new to rc cars, and recently got a RSX for my Tekin Gen 3 8.5t motor. Running it in a Losi SCT22 3.0.
The track I'm running at is really small and very slick surface and I've found that I need a lot of brakes. I ran another guy's car and I was able to hit the brakes at times to kick the rear end around. Now, I know in most cases, it's probably better to steer around corners, but on this given track, having the ability to "lock up" the rear end provides really beneficial.
I've been using the Hotwire to program via my laptop but I just can't seem to get it right. What I'm hoping to achieve is if I'm applying throttle, and rapidly push forward (reverse) on the trigger, the brakes apply and stop the wheels. I've got it tuned now so it slows the car in a pretty short distance, but still not quite aggressive enough. Would anyone be willing to point me in the right direction for this?
Any help is greatly appreciated.
LittleTreeGuy is offline
Old 04-03-2017 | 06:28 AM
  #1266
First, make sure you are getting full brakes on the speed control by applying the brakes on the transmitter and watching the LED lights on the RSX. They should ramp up from right to left as you increase the braking input and then should all flash when you are at full brakes.
Once that is confirmed, check your Brake strength setting and increase it to 100. This can be done directly on the speed control without hotwire. After that, you can go into the active brakes setting in hotwire. This feature is kind of a panic brake that will apply the brakes very aggressively if you quickly apply the brakes as opposed to easing onto them. Increase the number to make the panic brake setting more prevalent.
If this still doesn't get you the strength you need, then it might be more mechanical then electrical. What pinion and spur are you using? Going to a lower gear ratio (larger spur or smaller pinion) will give the motor more leverage on the drivetrain and multiply the strength of the brakes. If you don't need any more top speed, then going to a smaller pinion will get you more brakes. You could also switch to a larger diameter rotor for more brakes as well. I believe the stock rotor is 12.5mm, so you could pick up a 13mm High Torque rotor and you will have more braking power as well.
Another factor to consider is that your friend was using a different motor that has more natural drag built into it or was using a 4 pole motor that can generate more braking strength.
Krio is offline
Old 04-03-2017 | 08:57 AM
  #1267
IronRing Racing's Avatar
Some issues I'm experiencing with 258:
When you save a profile/program, the firmware version is wrong in the profile log, it's mistyped as Version "2" (in stead of "258"), so now it gives you the incorrect firmware error when you try to reload that profile, and worse, won't actually load any profile settings at all, just leaves you with the default settings again.
Secondly, since the "hold brakes to erase datalog" isn't turned on by default (?), and the setting gets reset during the firmware update, you have to do a run, go back in, and then make the selection. However, when you do this, at least on mine, it then does a complete factory reset, and you have to start over from the beginning. At this point, I am not able to activate the hold brakes to clear feature because of this.
Unfortunately I didn't discover either of these errors until after I updated and reprogrammed all 9 of my RSX's, so that's 2hrs the first time, then almost another 2hrs to redo them all...
I was the guy that had the problem with 255 where they would reset to factory settings after the 255 update and calibration. Sent in the profile data files, etc. that you asked I send, never got any response.
I finally determined that it was because I had used my previous 250 profiles to reload my settings into 255, and something was off in the checksum's in the compiler so it was resetting itself to factory defaults. So entering all of my settings manually was the final work-around. Wasn't a problem this time, lol, as the 258 profile saving error appears to render them completely useless from the beginning.
Aside from the above problems, in future, clearly indicating if previous profiles are, or are not, compatible with the new firmware would be very helpful.
It's hard to post problems without it coming off as negative, and certainly this was a frustrating half day spent just to update firmware, but please don't read it as anything but a little frustration. I like the RSX, and appreciate the new and exciting features you continue to bring out for the existing platform. It's drivability has continued to improve, especially the drive and brake frequencies! I'm looking forward to IOS Hotwire 3, and hope there's some way to save and reload profiles cleanly and quickly and so greatly reduce this firmware update time. I also understand most don't have 9 of these they have to go through. First world problems! Keep up the good work, just maybe a little more beta testing before release, these are some pretty basic features that got missed in this update (unless it's completely some issue on my end, which is always possible).
roffutt likes this.
IronRing Racing is offline
Old 04-03-2017 | 01:47 PM
  #1268
3n90t's Avatar
I'm having a similar issue with profiles. Mine had an error message too, but loaded 90% of my settings. I tried to resave but kept doing the same thing. Tried saving as a different file name but still same result.
I only have 2 ESC's to update... it took me over and hour. Lol
3n90t is offline
Old 04-03-2017 | 04:11 PM
  #1269
Tekin Prez's Avatar
Team Tekin
You guys are good... Appears you did find an interesting bug that we missed somehow. We already have it fixed and will be posting a new HW version shortly
freebird likes this.
Tekin Prez is offline
Old 04-03-2017 | 04:51 PM
  #1270
258.1 or 259?
freebird is offline
Old 04-03-2017 | 05:43 PM
  #1271
3n90t's Avatar
Any chance on future updates, that in windows, the app can be expanded to full screen. I hate the tiny window and tiny buttons on the app. I've only got a 15" laptop and trying to press tiny buttons is a pain for me.
The data logging window can expand to full screen though....
Please?
3n90t is offline
Old 04-03-2017 | 08:33 PM
  #1272
Thanks for fixing both the profile files and the resetting to factory defaults when you go into datalogs to enable hold brake to clear?
And please tell me it will read the 258 profiles I've saved and don't have to go back in and manually redo 9 speedo settings! lol
Honestly, because you have to load firmware, input/load your settings, disconnect, then calibrate your radio, then run a bit so there's data, then reconnect, go into datalogs, download, all just to enable the hold brakes to clear function, can you also please just enable it by default?
If people are datalogging, they use that feature and it should be default on. If people aren't, then they just don't care either way, so default on works just fine for them too.
Thanks again for the quick response.
Josh
roffutt likes this.
Old 04-04-2017 | 10:21 AM
  #1273
Randy_Pike's Avatar
Team Tekin
Post your brake settings you're using now. We can apply enough brake force to cause mechanical issues so let's see where you're at now.
Randy_Pike is offline
Old 04-04-2017 | 10:59 AM
  #1274
Randy_Pike's Avatar
Team Tekin
If people are data logging, they use that feature and it should be default on. If people aren't, then they just don't care either way, so default on works just fine for them too.
Josh
Your old profiles should be fine on v258 so no worries there.
You do not have to make a short run to access the data log adjustments. You simply need to "download data" and you should gain access to any changes you'd like to make, including the "hold brakes to clear data" function. It would go like this:
In the data log GUI, after clicking 'Erase Data', in order to access the 'data remote erase' checkbox the you must disconnect your ESC from the HW, then reconnect. This will power cycle the ESC and reboot it for the affect to take place. I hope that helps.
Old 04-04-2017 | 11:01 AM
  #1275
Randy_Pike's Avatar
Team Tekin
Please?
We are always moving forward to improve the usability of our Hotwire. This one has been noted
