Tekin RSX Thread
#1246
Thanks Yzracer... that's what I was told on the phone as well. Unfortunately, I had already soldered everything up and mounted it in my car when I realized this...
Plus, if the fan isn't really "NEEDed", I hate to be without an esc for a week or two...
#1247
Just installed a new RSX this weekend. I wasn't sure if I'd need the fan or not (running 8.5 motor in a 2wd SCT), but found that the holes in the ESC are bored a little too wide for the included screws. I contacted Tekin and they said I probably wouldn't need the fan at all but they are aware of the issue and would replace my ESC if I wanted to send it in.
Just wanted to pass along the info in case anyone else experienced this or if anyone comes here looking for the issue.
#1248
I agree with tech support. I don't run a fan on my SCT with a 7.5 and no issues. I ran the fan with an 6.5 in the 4wd but that was due to the ESC being in the back of the car in a tight space. Otherwise I have found it is not necessary in most cases. (may not have needed it in the fan on the 4wd but better safe then sorry).
#1250
In both my buggy and SCTI have always had a fan with my 8.5 combo. Never had an issue with heat. I am changing to 17.5 in the buggy, so from what I am reading, i won't need a fan with a 17.5? I have room for the fan under the body, so not a space issue, but if it isn't necessary, I might take it off. Good idea?
#1251
For stock I highly recommend the RS GEN 2 as it is significantly lighter and in stock lighter is better. However I understand spending money on a new speedo is not always an option and the RSX will do the job superbly as well. I would remove the fan to remove that extra weight as the RSX will power a 17.5 without even getting warm let alone hot.
FYI. RSX with Fan is 54g and RS GEN 2 is only 26g.
#1252
#1253
I must be missing something. I downloaded hotwire from that page again, same result. I don't see a link that states 255 installer. Everything link seems to be a guide of some sort. Really want to play with the new software as the outdoor season approaches. Thanks for helping.
#1254
·Better throttle control and feel
·Improved braking response and control
·Increased ESC circuit durability across all platforms
·Adjustable Throttle and Brake Frequency
·Improved power management
·New Fault code for fan plugged in backwards OR Futaba transmitter off
·HotWire 3.0 BLE compatibility
Version v258 shows HotWire 11.34.3
Compatible with RX8 Gen3, RX8 Gen2, RX4, RS Gen2, RS Gen2 Spec, and RSX.
#1255
V258 Release Info:
Awesome! I will update my RSXs tonight!
#1256
Question for the tech experts about the RSX and datalogging.
I have 2 RSX esc's.
In the Datalogging I find:
ESC #1 shows throttle position at full being 82, and there is no fluctuation
ESC #2 shows a throttle position at full being 83.69 and it will fluctuate to 85.26 randomly.
I use the exact same transmitter to control both ESC's, so if it was a noisy throttle pot I would think both datalogs would show the fluctuation.
The ESC's are in 2 touring cars with the exact model receivers, same servos, and fans. The only difference is one is a 17.5 and the other is a 21.5. It is the 21.5 I see the noise in the throttle datalog.
Any ideas as to what could be going on?
I have 2 RSX esc's.
#1257
V258 Release Info:
#1258
The functionality is the same.
#1260
I have 2 RSX esc's.
I have 2 RSX esc's.
As long as you're getting WOT or wide open throttle which you can verify with your ESC's LED tree showing all LED's ramping up and flashing you're good to go.
95Likes
