Like Tree95Likes
Tekin RSX Thread
Old 10-07-2014 | 06:31 AM
  #646
Hi I have just decided to start racing again after a 7 year break. Have bought an xray 1:10 xb4 for off-road and an 2015 spec xray 1:10 touring car. Will be running tekin 6.5 motor in off-road and 13.5 in touring. My question is I'm after two speedos and love the look of the rsx but being built for more modified racing will it suit the touring car with a 13.5 t motor??? Help please :-)
Team Ikas is offline
Old 10-07-2014 | 06:47 AM
  #647
fredmotokx's Avatar
For your touring car you can use a Tekin rs gen2.
fredmotokx is offline
Old 10-07-2014 | 06:52 AM
  #648
Ok thankyou. That was one of the other ones I was looking at. Things have changed so much in 7 years part of me was hoping to keep them the same lol to keep set up simple.
Old 10-07-2014 | 09:42 AM
  #649
Randy_Pike's Avatar
Team Tekin
the RSX esc will suit you in any class you put it into. The only class it doesn't belong in is 1/8 and 4wd SC.
For 4wd mod buggy and 13.5 TC you'll be very happy with the RSX.
Randy_Pike is offline
Old 10-07-2014 | 10:01 AM
  #650
Ray Kindstrom's Avatar
Thanks RP - ordered.
Ray Kindstrom is offline
Old 10-07-2014 | 10:07 AM
  #651
sduffy77's Avatar
Originally Posted by Randy_Pike
Ok, stop. If you have power going to the esc and it won't turn on this is the last test.
Unplug the fan if equipped, unplug the esc from the receiver, unplug the sensor harness from the esc. Power up the esc? Does it light up?
If not it needs service. Contact [email protected]
I contacted support for an RMA... also this weekend had my new Pro4HD motor in my 4x4 stop working... not a good week for me
sduffy77 is offline
Old 10-07-2014 | 10:44 AM
  #652
Can I use the RSX without the fan on my b4.2? if it matters, I'm using 8.5t motor.
ebay007 is offline
Old 10-07-2014 | 10:45 AM
  #653
Randy_Pike's Avatar
Team Tekin
Yes, you don't have to run the fan if you don't need it.
I don't run one on my 4wd buggy most of the time.
Old 10-07-2014 | 01:27 PM
  #654
Ok. Thanks.
ebay007 is offline
Old 10-29-2014 | 07:54 PM
  #655
tommytom's Avatar
How is the reliability of the tekin rsx? I had 2 rspros die pretty quickly on me, and my father and brother had problems with their original RS escs. I made the switch to speed passion for a bit, but thinking about giving tekin another shot as after almost two years my speed passion reventon pro died tonight. It just scares me to spend 220.00 on a esc and possibly have poor reliability like my last two tekins.
tommytom is offline
Old 10-29-2014 | 08:28 PM
  #656
Clegg's Avatar
Moderator
I run on road, but I have yet to see a RSX fail. For that matter same with the Gen2 hardware. I've been pretty impressed. Only G2 era ESC I've seen fail personally, was plugged in backwards.
Clegg is offline
Old 11-10-2014 | 10:34 AM
  #657
ironzgti35's Avatar
Are you guys using higher gauge wire so it will fit into the post like on rx8's or just laying the wire on top of the post? Benefit of one vs the other. Going into a HB D413
ironzgti35 is offline
Old 11-10-2014 | 11:19 AM
  #658
jmcelroy42's Avatar
I used the wire that came with it. Tinned the wire then smashed it flat with a pair of pliers while still warm. then stuck that into the groove on the posts of the esc. it doesn't all fit in there obviously some will be on top of the post still, but I think that will give you the best connection.
jmcelroy42 is offline
Old 11-10-2014 | 01:06 PM
  #659
Randy_Pike's Avatar
Team Tekin
You can solder the wire on top, on the side, downwards, upwards, however it suits your car.
The slot is there to help hold solder and add more "edges" to make a stronger connection. Some wire can make it's way down there but it by no means is required.
Old 11-14-2014 | 07:19 PM
  #660
Running RSX with Tekin 13.5 redline RPM in a Losi 22 2.0 MM 2wd buggy. Have been using hotwire to set it up but need some advice. What is the safe range for timing advance on this setup? I cant seem to find any complete speed control setups for 13.5 anywhere. Is there any benefit to mechanical advance over programmed or is it ultimately the same?
Currently running boost of 20 and turbo ramp 2 with no delay with curve 2. High traction clay, tight track. 27/78.
Danger Dietrich is offline
