Tekin RSX Thread
#616
Anyone know where to buy and OTG cable for the Hotwire. Someplace local where one need not be ordered. Im looking for female usb to micro usb. To be used with Samsung Galaxy S5. I also wondered if they made a micro usb to mini usb both male for a direct connect. Let me know your thoughts. Thanks.
#619
#623
i was racing my b5m when i hit a hard bump. there was a loud sound out of my motor and then then my rsx went into error mode 1,2,6,7. i switched out the motor and still the error msg occurred. i soldered the teeing gen 2 motor to my backup hobby wing esc and the motor worked fine. So I think the problem is in the rsx. but how come it switched to this error after a hard bump? I'm thinking of sending it back for repair but is there anything i need to check before i do that?
#624
I've seen motor wires so close that a small nudge of the tabs caused a short.
#626
If the code is still there, it will need service assuming the motor and A B C wiring is know to be good.
www.teamtekin.com/service.html
#628
#629
#630
If you're coming off the track and it shows 4 led's after a full run, you're good.
You can use the data logger to verify your esc heat at the end, just make sure you clear the run before you test, so you're getting the latest data.
95Likes
