Like Tree95Likes
Tekin RSX Thread
Old 05-02-2014 | 01:03 PM
  #466
Sorry for such noob questions~ I've never had to solder on a cap before.
1: Do I need to insulate the cap's wires at all if I solder them on the top of the post and run the cap to the bottom? (where the wire may touch the PCB.)
2: with this wire layout should I maybe just put the cap on my battery leads and just use some heat shink tube to keep it in place?
3: should I maybe get a different cap that I could run a wire around to the front side of the RSX?
Thanks~
Ben
PS. How's the build treating Jeremy Potter??
erevo1*16 is offline
Old 05-03-2014 | 07:52 AM
  #467
fredmotokx's Avatar
Originally Posted by fredmotokx
Some one have the dimensions of the fan? Mine is broken from the factory and I can not find anywhere (tower,amain). The # is TT3833, if some one know a decent replacement fan, I would like to know. My esc came back at 145 and motor 120 after 7-8 minutes running no fan with timing profile #2 everything else is stock and a tekin redline gen2 6.5T. I think I need a fan on my RSX.
Same thing happen yesterday, I run my car 7 minute non stop, the speed was at 147, the motor was around at 120. My gearing is 18T with a 84 spur in my TLR 22-4, esc is on factory setting no fan. One guy at the track is running the same combo as me and his speed is never going up 120 in a b44.2. I am wondering if my esc is having a problem and I should send it back to tekin in a RMA? I have my esc since 23 february.
fredmotokx is offline
Old 05-05-2014 | 04:06 PM
  #468
fredmotokx's Avatar
Maybe some one know a possible issue? I re-soldered everything. I still have 2 month before the warranty end, so if I have to send it back, I rather do it soon for the warranty.
Old 05-05-2014 | 07:38 PM
  #469
dski's Avatar
When you say the other guy setup is the same, is everything the same?
Same speedo, same motor (turns, rotor, timing, brand), identical gearing, and same amount of airflow to the RSX?
I'm not sure 147 is that alarmingly hot - gearing and airflow, etc maybe the difference.
dski is offline
Old 05-06-2014 | 04:06 AM
  #470
fredmotokx's Avatar
He have the same combo RSX/6.5T in a b44.2. Maybe I should wait to receive a fan from tekin. Sorry if I sound a bit paranoiac about my RSX, at the price I paid it, I am sure you guys understand.
Old 05-06-2014 | 07:27 AM
  #471
BRSracing's Avatar
Randy or someone from Tekin, I have a B5M, not a lot of room for electronics. I am not running a fan. Can the capacitor be mounted forward like on the RS gen2?
And if anyone has pics of there seteup post them please.
BRSracing is offline
Old 05-06-2014 | 08:15 AM
  #472
dski's Avatar
No worries. I understand. I don't think you're at any risky point. Are you running any ESC timing?
Looking at the manual for example, the ESC has 7 on board temp steps. you're only at 3 of 7... Looks like the safety thermal shutoff isn't until 220F.
dski is offline
Old 05-06-2014 | 08:45 AM
  #473
fredmotokx's Avatar
I will wait for the fan before do more test. Thanks you for your help.
Old 05-06-2014 | 09:00 AM
  #474
Randy_Pike's Avatar
Team Tekin
Thanks~
Ben
You can run it off the back, or remote wire it but note try to keep the leads as short as possible.
Randy_Pike is offline
Old 05-06-2014 | 09:02 AM
  #475
Randy_Pike's Avatar
Team Tekin
There's nothing wrong here. He's driving a shaft car with some air flow in the chassis due to layout. You're running a belt car(more drag) with NO airflow to the esc due to the belt tunnel. 147 isn't even close to hot yet on the RSX. Note you should ALWAYS use the onboard temp monitor via the led tree to verify temperatures, or use the data logger
  #476
Randy_Pike's Avatar
Team Tekin
Yes you can mount the cap either way.
Old 05-06-2014 | 10:17 AM
  #477
BRSracing's Avatar
Thanks Randy, ESC is great, well worth the wait!!!!! And the new Anroid app is awesome as well.
Old 05-06-2014 | 10:36 AM
  #478
Team Pink's Avatar
Saw your post on this thread and the B5M thread as well. Here is the RSX all wired up in my B5M.
Team Pink is offline
Old 05-06-2014 | 12:19 PM
  #479
Casper's Avatar
You got some thin gauge wire on that setup. Not saying it is wrong but thinner then what we typically see. Is that 14g?
Casper is offline
Old 05-06-2014 | 12:43 PM
  #480
Randy_Pike's Avatar
Team Tekin
Looks like it...14awg can be ok in 2wd mod but keep an eye on the temp of the wire after a run...
