FlySky FS iT4 Transmitter Thread >
Like Tree3Likes
Old 11-30-2014 | 09:45 AM
  #511
malaval_ren's Avatar
Hello Charles, All,
Your FS-iT4 is a first generation.
Mine is a second generation.
The firmware is sure for a second generation of FS-iT4.
The latest version is 1.02US 07-12-2013
Do you have contacted Flysky by mail ?
Do you have configured your FS-iT4 to "FS-iT4 emulator" in sub menu called "USB menu" ?
Does your FS-iT4 is it discovered by the update software on windows ?
Note: Until you click on the "update" button nothing happens.
Do you really need to update your device ?
If you want to be secure, don't update yours FS-iT4....
Regards,
Renaud
malaval_ren is offline
Old 11-30-2014 | 02:35 PM
  #512
i need to up date to bind more than one model at a time
cbfsoar15 is offline
Old 11-30-2014 | 02:44 PM
  #513
MikeGozz's Avatar
Have you tried? The multi bind issue is a hardware issue not a software one.
When I installed my chip I was all set. No FW update needed.
MikeGozz is offline
Old 12-03-2014 | 11:11 PM
  #514
mattie696's Avatar
Originally Posted by mattie696
I've contacted Fly-Sky about the issue and recived an promptly email that replied that they would send an SMC chip to solder into my existing FS-iT4 Transmitter. (grey) Received the chip 3 weeks later. I took apart the Tx with excitement only to remember that ive only solder a handful of times When I got to the actual board I Disconnected the Tabs and thought better to just find someone to solder it on.
The IC chip reads "D1116-TG81421"
UPDATE
I got the firmware update for version 1.01-US. 22-01-13 from Fly-Sky. Here is the link provided below. I have not used it yet, still waiting to get the IC chip solder on
Firmware update
https://drive.google.com/file/d/0B1b...ew?usp=sharing
Instructions
mattie696 is offline
Old 12-05-2014 | 05:47 PM
  #515
Hi guys,
do you know if the 4ch rx that comes with the radio, can handle a 2 lipo?
BuggerRc is offline
Old 12-05-2014 | 05:52 PM
  #516
mattie696's Avatar
Originally Posted by BuggerRc
Hi guys,
Yes it can, if your running HV servos
Old 12-05-2014 | 05:58 PM
  #517
i have hv servos. so i can plug directly to the rx the 2s lipo? is for a 1/5 scale rc car.
BuggerRc is offline
Old 12-05-2014 | 06:08 PM
  #518
mattie696's Avatar
You will need to make Shore your power switch has the right connectors (deans ie) to plug the Lipo too. Haveing a glitch buster will help regulate the voltage.
Old 12-06-2014 | 07:28 AM
  #519
The manual states 6.5v max for the receiver. But, it can take the 2s lipo???
BuggerRc is offline
Old 12-07-2014 | 11:00 AM
  #520
No one has used the IT4 receiver with a 2 lipo?
BuggerRc is offline
Old 12-08-2014 | 05:39 AM
  #521
I just picked up a Fly Sky iT4 radio package in shiny orange chrome colour from a local seller and included with the radio is a Fly Sky FS-GR3C receiver. I can't seem to get the transmitter to bind with this receiver. I am wondering if perhaps this receiver just isn't compatible with the iT4 transmitter. Can anyone help?
SteveM is offline
Old 12-08-2014 | 06:55 AM
  #522
mattie696's Avatar
Sorry to say but that Rx is not compatable with the it4.
Old 12-08-2014 | 09:19 AM
  #523
Thanks.
SteveM is offline
Old 12-08-2014 | 09:54 AM
  #524
Steve,
Don't own this radio, but from researching and reading thread, I think your older AFHDS receiver should work.
If your transmitter is the latest ic chip hardware and firmware, there should be a option in the transmitter to switch from afhds2 -- afhds.
Change setting to AFHDS and try binding.
Hope this helps
Al
abasualdo is offline
Old 12-08-2014 | 10:16 AM
  #525
mattie696's Avatar
The iT4 Transmitter will bind to the FS-iR4 AFHDS2 Receiver (what came with my iT4 TX). Hope this helps!
