Lap Timing Decoder
#361
1 1/2 years later, and this thread gets better and better!
I was previously unfamiliar, but I liked this description...
http://web.mit.edu/6.02/www/f2010/ha...ectures/L9.pdf
#362
http://www.rctech.net/forum/12222187-post251.html
howardcano,
LOOP CONSTRUCTION:
Use 18 AWG stranded, insulated wire. Wire must terminate as closely as possible to loop amplifier input, with minimal lead-in length. Place loop 12" above track.
9'x1' to 12'x1' : No jumpers on loop amplifier.
6'x1' to 8'x1' : Use jumper at J3 on loop amplifier.
3'x1' to 4'x1' : Use jumper at J5 on loop amplifier.
On your loop PCB, J4 is not use ? is always ON ?
howardcano,
LOOP CONSTRUCTION:
#363
howardcano,
LOOP CONSTRUCTION:
howardcano,
LOOP CONSTRUCTION:
#366
Hello Howard,
Great project! i came across this from finding your transponder design thread. Now i have went through alot of it skip some pages, im no electrical engineer but i am interested in this as a low cost system for our club, we are using the Robitronics but its not very accurate and its difficult to get people to spend $45 for that transponder on top of the MyLaps RC4 they already have. We certainly cant afford a RC4 decoder.
So if i can build something affordable and hand out transponders for free or for very little charge then we can hold more races and even invite others.
1. From what i understand you have a working decoder with transponders?
2. Do you have an final plans with a list of materials? instructions?
3. Which timing software is compatible with your decoder? We use Flip Side Racing (opensource) i think that fits well with your project!
is anyone using this at a track sucessfully ?
thanks!
thanks!
#367
Hello Howard,
thanks!
thanks!
Here are some answers to your questions:
1) Yes.
2) Send me your email address in a private message and I'll send all of the info.
3) Flipside and Zround.
I'll let our readers respond to your last question.
This is a very complex project, if you are not extremely knowledgeable in electronics, you'll need to enlist the help of a friend!
#368
It's been nearly 10 months since I posted the specs, so for those who have not read through the entire thread (which is getting quite long now!), here they are:
1) Yes.
1) Yes.
Thanks for the quick reply, yes i am possibly able to do this but if not i have friends who are electrical engineers and others that understand electrical so i can get help.
I will PM you now with my email.
thanks!
#370
Thats very good to hear! All of this pogress is amazing, we cant thank you guys enough!
#371
howardcano,
LOOP CONSTRUCTION:
howardcano,
LOOP CONSTRUCTION:
Would the loop work with FlatWire? (taperwire) http://www.taperwire.com/
or other kind of flat wire?
thanks!
#372
Can the detection loop be installed under a carpet or on the carpet covered by tape? Would like to do this without a bridge.
thanks!
thanks!
The gauge of wire affects the tuning slightly, but the biggest reasons I chose 18 AWG were strength, low cost, and availability. You can go thinner if you want to get the carpet to lay flatter, and you can also use ribbon cable with several conductors wired in parallel. Both of these options will likely be cheaper than any specialty wire.
#373
I think you'll have good luck as long as the floor isn't conductive. But even concrete can have rebar that will mess up the signal.
Yes ribbon cable sounds like a good idea. Our carpet is directly on concrete so yes there is rebar near by, actually our track is in a basement so we are surrounded by concrete!
Can i shield the ribbon cable from the concrete floor? what could be used to do that?
thanks!
#374
thanks Howard,
thanks!
thanks!
The loop is affected by any conductors nearby, so shielding is exactly the opposite of what we want.
My advice is try it and see how it goes. If you encounter problems, you can always go back to the original loop specification.
#375
It's time for a celebration! This thread is now 16 months old, and just surpassed 50,000 views.
Thanks to all of you for your interest. I hope you have found it fun and informative.
8Likes
