Like Tree3Likes
Transponder Design
Old 01-13-2014 | 12:24 AM
  #166
Hello to all you guys!
pa3exv nice job.
Is it possible to get original files, not jpegs, to build those transponders and try them with Payalneg's decoder?
maeg is offline
Old 03-21-2014 | 07:35 AM
  #167
Just my development clone of mrt transponder. Works with mylaps rc4. Size 19x21mm.
Payalneg is offline
Old 03-21-2014 | 02:43 PM
  #168
Awesome work Paypalneg! I've been working on an alternate input amplifier for my decoder, to be used with a loop that has a 470R resistor. More news in the decoder thread if I have success (it is very nearly done).
edeca is offline
Old 03-22-2014 | 01:12 AM
  #169
Yeap,
and two amplifiers with filters in decoder. This box is compatable with amb decoder
Payalneg is offline
Old 03-22-2014 | 02:03 AM
  #170
Yeap,
Do you have a schematic? I can see a custom wound balun and I assume the capacitors are for filtering, but I don't see any amplification?
What sort of signal level do you get from yours? And how do you amplify it afterward? I am simply using opamps and a comparator now to turn the signal back into a digital pulse train.
My first attempt was a custom winding on a binocular core, this worked OK but wasn't amazing:
The newest one works much better and uses a Mini-Circuits transformer as a balun:
Unfortunately with a 470R resistor in the loop the second one is targeted at a 52R impedance system (the balun is 1:9) but that doesn't matter as I'm not attempting compatibility with AMB.
edeca is offline
Old 04-17-2014 | 01:31 PM
  #171
Originally Posted by howardcano
The transponder is compatible with AMB, just like the MRT transponders.
The decoder, should I complete it, would also be compatible with MRT and AMB transponders (the ones currently used, not the new AMBs that are causing the ruckus.) One difference is that the decoder would show different numbers than are printed on the AMB transponders, since I don't know the data encryption format. But that is of no significance to the user, as each would still show a unique number that can be associated to a individual car/driver.
Bingo!
This is exactly what is needed a decoder compatible with AMB & MRT transponders.
If a less expensive decoder was available and with compatible transponders then that would make switch over easier for track owners.
So you say to have tested with amb then you mean rc2 & rc3 not the new my lalps rc4?
rc-demon is offline
Old 04-17-2014 | 04:12 PM
  #172
howardcano's Avatar
Originally Posted by rc-demon
Bingo!
Compatible devices for the decoder are in the decoder thread, in this post of the decoder specs:
http://www.rctech.net/forum/12222187-post251.html
howardcano is offline
Old 04-23-2014 | 07:07 AM
  #173
It's not the howard design?
you use an attiny25 and 20MHz oscillator ?
only 2 layers ?
luluFRA is offline
Old 04-25-2014 | 02:20 AM
  #174
only 2 layers ?
attiny25 with 20mhz crystal and 4 layers pcb.
Payalneg is offline
Old 04-25-2014 | 03:06 AM
  #175
Does your transponder work with RC4 decoder?
Any chance you share your design with us?
There are some great work done on this forum
Regards.
pitas is offline
Old 04-25-2014 | 03:18 AM
  #176
ok thanks, but it's not the same design like this link ?
http://www.rctech.net/forum/radio-el...ansponder.html
thanks.
luluFRA is offline
Old 04-25-2014 | 03:22 AM
  #177
Regards.
Its works with rc4 decoder. Sorry, no design.
Payalneg is offline
  #178
Yeap,
Great job !
Can you share schematic ?
luluFRA is offline
Old 04-25-2014 | 09:04 AM
  #179
kinetisist's Avatar
I would love to build my own mylaps hybrid compatible transponder ... is there a kit available?
kinetisist is offline
Old 04-25-2014 | 09:05 AM
  #180
+1
pitas is offline
