SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 12-27-2015 | 07:57 PM
  #3931
I ran the 100c shorty 5 more cycles today and I'm down to 1.5 IR. Here's a pic at 1.6 / 1.7. The next cycle was 1.5 / 1.5
Attached Thumbnails SMC LIPO BATTERY THREAD-12434331_1104588672897261_654885877_n.jpg
Bob Barry is offline
Old 12-27-2015 | 09:06 PM
  #3932
JDM_DOHC_SiR's Avatar
Nice.. I was able to get 4 more on mine as well.. 10 total now and my IR's or close to that 1.7 range ... have a feeling that it will do down a bit more too
JDM_DOHC_SiR is offline
Old 12-27-2015 | 11:22 PM
  #3933
thecman26's Avatar
R/C Tech Elite Member
Wow, you guys got the pick of the litter!
I am about 20 cycles in so far on my 100C pack and I am down to about 2.5/cell.
thecman26 is offline
Old 12-27-2015 | 11:25 PM
  #3934
RC*PHREAK's Avatar
how many amps are you charging at? note the temp of the pack at the bottom at almost 106 degrees. charged at 20amps (and probably discharged at 20-30a prior to charging). if you are getting your 2.5 reading with a room temperature pack, then you're comparing apples/oranges.
RC*PHREAK is offline
Old 12-27-2015 | 11:30 PM
  #3935
thecman26's Avatar
I can only charge at 20 and discharge at 10, temps around 92*.
Old 12-28-2015 | 06:52 AM
  #3936
That's actually the charger's internal temp. I discharge at 30amps, wait one minute, then charge at 20. if you use a temp gun on the battery, it will probably be around 110.
Old 12-28-2015 | 10:56 AM
  #3937
RC*PHREAK's Avatar
Ok, so big difference in 92 and 110. Cman, I'm sure your packs are fine.
Old 12-28-2015 | 11:01 AM
  #3938
Davidka's Avatar
Makes me question the value of testing at very high charge/discharge rates. I don't think my batteries have ever gotten as warm as 100f by the end of a run in stock racing.
Davidka is offline
Old 12-29-2015 | 10:19 AM
  #3939
WIGMAN's Avatar
I am curious....the guys that are cycling the 4000 100C shorties....what kind of MAH are you coming up with?
WIGMAN is offline
Old 12-29-2015 | 10:31 AM
  #3940
Are you guys trying to heat your batteries ?
bring it on is offline
Old 12-29-2015 | 04:40 PM
  #3941
Wink
Originally Posted by Davidka
Worth noting: mah and "c" ratings are arbitrary figures based on how much power (voltage) a battery will provide at load, across a measured amount of time (expressed as mah). I believe these numbers are also theoretical. Is it possible for a battery to push 400amps continuously? Can that be tested without melting connections & wires? If a battery were loaded with 400amps, would it provide 4000mah above threshold voltage?
I'm thinking the 4000/100c is more energy dense, therefore heavier. I would not be surprised if it could easily be rated at a higher mah and lower c (assuming it is fairly rated now).
You are confusing C rating and actual capacity. Ampere-hours (or mAh, milliampere-hours) is a measure of electric charge. It is a real measurement and the rating of the pack will reflect the designed/nominal/intended usable capacity. If you have a nice charger with a display, you can see how much charge (mAh) you are actually putting into or pulling out of the pack. The pack's rating will be based on an assumption that it is charged and discharged between certain voltages. You can, of course, discharge further with the risk of damaging the pack. (If you're curious, energy would be given by voltage times mAh. Typically, electrical energy is expressed in watt-hours or kilowatt-hours. Assuming an average voltage of 7.4 V, A 2S 4000 mAh pack would be 7.4 V x 4 A x 1 h = 29.6 Wh, regardless of C rating.)
The C rating is the highly variable, often manipulated characteristic of a pack. I believe Danny has a good write up explaining this on his site and probably on this thread as well. Part of the C rating has to do with the actual cell chemistry, but part of it is assuming an acceptable internal resistive drop.
I would speculate the 100 C pack to be heavier due to cell geometry and/or increased internal conductor thickness (which lowers IR and allows a higher current). But you won't get any more energy out of a 100C pack than you can out of a 1C pack, given the same cell count and charge capacity. Of course you can go really while fast discharging a pack at 100C into your motor, but only for 36 seconds. On the other hand, your motor can pull at 1C and go much slower, but you'd last a whole hour.
...all that to explain that the 100C pack is no more energy dense than the other. And to your point of the practicality of discharging at 400 A continuously, I really wouldn't recommend that. Given that it would only last 36 seconds, maybe doing it and allowing ample time to completely cool back down is feasible, though I would suspect long-term damage from doing this repeatedly. I'd never design a 400 A conductor with 12 AWG wire in a satellite; then again, we can't easily go up and fix it when it fails. In the world of RC, however, these limits are pushed because it's not a catastrophic event in the grand scheme of things if your battery overheats or wire melts during a race. A DNF really isn't that bad in comparison. It's also normal for a racer to replace packs every year, if not more frequently.
I'm sure that's way more than anyone wanted to know, but just trying to give a perspective on ratings. Some ratings (such as the C rating) depend on the intended use and acceptable failure rate, which can be wildly different going from military to consumer to hobbyist.
Callaway is offline
Old 12-29-2015 | 08:03 PM
  #3942
RC*PHREAK's Avatar
Yeah Rick, that's the idea behind discharging and charging at high rates. You heat up the battery's internal temp which lowers IR. The trade off is potentially safety and battery life. Which is not to mention that it's against ROAR rules but tracks don't care soooo....
Old 12-29-2015 | 08:52 PM
  #3943
This must be a stock class thing? We don't have the stock class here where I race...
Old 12-29-2015 | 10:17 PM
  #3944
RC*PHREAK's Avatar
Yes, definitely a stock class thing.
Old 12-30-2015 | 05:22 PM
  #3945
ok, That's what I thought
