SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 08-13-2013 | 05:56 PM
  #2146
Danny,
I am wondering your thoughts on letting batteries cool before charging again. If so, how long do you recommend. FYI I usually wait at least 40 min. before charging again...
SouthFloridaApp is offline
Old 08-13-2013 | 06:28 PM
  #2147
Questions??
That's a good question. Because my packs always charge cool-to-the-touch I thought that it was OK to charge them if I just pulled them out of a truck a bit warm. (i.e. they're going to cool at the same rate anyways, since charging isn't adding heat).
If charging them when they're still a bit warm is hurting them... then I've been damaging mine on track days (for bashing there's never a rush to charge)
PetRock is offline
Old 08-13-2013 | 06:39 PM
  #2148
I'm not Danny but I see no issue with charging a warm pack just out of the car. Charging lipos does not add any heat. This ain't red cell NiCad days.
In my totally un-scientific opinion, charging a warm lipo pack might actually be better for it as a warm back has lower IR than a cooler pack.
kcobra is offline
Old 08-13-2013 | 07:57 PM
  #2149
rcjunky1's Avatar
I've always wondered the same, we'll see what the master has to say, but lipo warming was a bit of a thing before ROAR banned it due to the home made contraptions people were using, but a warm pack has a lower IR and should get a better charge with less wear on the pack, meanwhile some say let them cool first. I've never heard a clear educated response.
rcjunky1 is offline
Old 08-13-2013 | 09:15 PM
  #2150
Hoese37's Avatar
Danny,
They shouldnt be much warmer than ambient temperature. If they are, something in your setup is off.
You can just start charging as soon as your done, but I like to let them sit for 5-10 so the cells can equalize.
Hoese37 is offline
Old 08-13-2013 | 10:46 PM
  #2151
gticlay's Avatar
1400mah Sanyo SCR's rocked! That's what I was running in my Avatar pic
gticlay is offline
Old 08-13-2013 | 11:27 PM
  #2152
Danny/SMC's Avatar
Company Representative
Originally Posted by Mullet1
4s's coming soon?
Started to fill out pre-orders today. We won't have enough to fill out all pre-orders. I will post up to what number we were able to make it tomorrow afternoon.
Danny/SMC is offline
Old 08-13-2013 | 11:29 PM
  #2153
Danny/SMC's Avatar
Danny,
You can charge them when they are warm especially if you use 1C or 2C for charge rates. They will actually cool down while charging as at those rates it really doesn't heat up the cells much.
My cycle life testing consists of 50 back to back cycles with 10 minute delays and after this test a good pack only drops 0.8 to 1.2% of it's mAh and the IR stays the same.
Old 08-13-2013 | 11:36 PM
  #2154
Danny when will yours have a importer in Australia so we don't have to worrie about importer lipos
RavensNightFury is offline
Old 08-14-2013 | 06:35 AM
  #2155
DarthRacer's Avatar
I've never had a lipo warm up during a race. They get popped right back on the charger after marshaling duties so they get about a 10min resting period between use and re-charge.
DarthRacer is offline
Old 08-14-2013 | 07:00 AM
  #2156
Real quick question. I bought two packs from you and noticed something a little strange about one of my 2S 5100's. I always balance charge both packs. For some reason on the second balance charge of battery number 2 it will only charge to 4.19 and 4.2 volt each. The other cell will balnce charge to 4.2-4.2. Is this normal?
Thanks,
Eric
Bignose94015 is offline
Old 08-14-2013 | 07:06 AM
  #2157
Darkgenerals's Avatar
R/C Tech Elite Member
I guess you've never ran SC before, my SCTE warms the bats up pretty good. 110 to 115 when ambient is 95ish.
Good to now I can charge right after running, I usually let them sit for 5-10 mins before I start to charge them.
Darkgenerals is offline
Old 08-14-2013 | 07:08 AM
  #2158
Hoese37's Avatar
Read my sig.
Hoese37 is offline
Old 08-14-2013 | 07:09 AM
  #2159
Read my sig.
lulz reading failure on my part, my bad. Still all of my bats come off warm from my SCTE, and my sc10 4x4.
Old 08-14-2013 | 07:15 AM
  #2160
Hoese37's Avatar
Ive had them come off warm to the touch, but not hot.
Hoese37 is offline
