SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 08-14-2013 | 07:21 AM
  #2161
Darkgenerals's Avatar
R/C Tech Elite Member
Originally Posted by Hoese37
Ive had them come off warm to the touch, but not hot.
I thought from your post, you meant they should be ambient temp.
Darkgenerals is offline
Old 08-14-2013 | 08:14 AM
  #2162
Originally Posted by Danny/SMC
I would get the 6500-70C this is the best deal for a high end pack. You can run one pack in your SC so run it for all the heats and final. I started racing again and have a 5600 for my 2wd buggy and a 5600 saddle pack for my 4wd. I run the same pack all day long.
I was leaning towards the 6500.. Is that all heats and races on one charge? If so that's rad! I am running novice at that so it's 4/4/5 so that would be cool if I only needed one? I have the X4 hitec charger it only goes to 6amps? charging it lower wont hurt will it?
cripplethreat is offline
Old 08-14-2013 | 08:23 AM
  #2163
no, charging lower than 1c would never hurt a bat. I would bet hes charging between races. Its easy to throw your bat on the charger at 6amp between races, I would be impressed tho, if some one was using 1 battery with just one charge for the hole race.
Old 08-14-2013 | 08:50 AM
  #2164
Hoese37's Avatar
I run a 6500 in my 2wd Kyosho SC. I can do two quals and a main with out recharging.
Hoese37 is offline
Old 08-14-2013 | 09:19 PM
  #2165
Danny/SMC's Avatar
Company Representative
Originally Posted by Bignose94015
Real quick question. I bought two packs from you and noticed something a little strange about one of my 2S 5100's. I always balance charge both packs. For some reason on the second balance charge of battery number 2 it will only charge to 4.19 and 4.2 volt each. The other cell will balnce charge to 4.2-4.2. Is this normal?
Thanks,
Eric
Wish I would have an answer as to why this is happening but I don't. That really isn't a big difference and nothing to worry about.
What kind of charger do you have ?
I'm sure if I was to charge this pack on my PL8 that both cells would be the same. I think some chargers don't balance at the same level. For example the PL8 has all kinds of adjustments to set the precision of the balancing so I could set it to not balance as well or set it to balance real well. I suspect it might have to do with the resistance the your charger is seeing but this is just a theory.
Danny/SMC is offline
Old 08-14-2013 | 09:25 PM
  #2166
Danny/SMC's Avatar
You can use the same pack 40 times in a day if you want all it does is use up it's cycle life. So whether you run it 40 times in one day or 1 time a day for 40 days this is basically the same for the pack.
What I recommend is you have 2 packs as it's always good to have a spare plus if you go for practice days you can run a pack while the other is charging so basically you could be on the track all day long with very small delays between runs.
If you plan on being in RC a good charger with higher charging capabilities is a good thing. Your 4 channel charger is OK but in my opinion a charger with one channel that can do 12 to 20 amps is better.
Old 08-14-2013 | 09:31 PM
  #2167
gticlay's Avatar
So, at what amps could I completely safely charge the shorty packs? Planning to buy a few and motors to go with them.
gticlay is offline
Old 08-14-2013 | 09:32 PM
  #2168
Speaking of charger adjustments, I also have a PL8. Do you mind sharing your presets for accurate,high power and storage charging modes?
dirty_rooster is offline
Old 08-14-2013 | 09:42 PM
  #2169
Danny/SMC's Avatar
You can charge up to 30 amps and the pack will take it but the problem at these higher rates is most chargers will not give you a full charge. With that in mind I think 10 to 15 amps is ideal.
Old 08-14-2013 | 09:50 PM
  #2170
Danny/SMC's Avatar
Never used accurate.
I use high power. I don't have access to the CCV program now but here are the key things I set. All the rest is pretty much what they have it set at.
Balancing:
Start at 4v
1000mAh
Only on charge not on discharge.
Termination:
Manual termination set at 500mAh. What this does is regardless of the amp rate you charger at the pack will always get the same amount of charge. So at 2 amps or 40 amps you will get the same charge.
Charging:
4.205V per cell
Use the amp rate you prefer for charging.
That's all I can think of for now.
Storage mode I use how they have it setup and will use a higher amp rate if I'm in a hurry.
Hope this helps.
Old 08-15-2013 | 06:59 AM
  #2171
mxgregg's Avatar
Balancing:
Start at 4v
1000mAh
Termination:
Charging:
4.205V per cell
Hope this helps.
Danny,
I just bought a PL-6 with a FMA board to charge multiple packs at once. Should I use the same settings listed above? Also what is FMA wiring mode vs. XH/EH. What are your batteries setup for?
Thanks Gregg
mxgregg is offline
Old 08-15-2013 | 11:41 AM
  #2172
How much larger is 2x 2S race packs vs 1x 4S. I'd like to get some batteries, but I'd rather not wait for the next shipment. Just trying to get a feel for how much taller it will be.
simon021 is offline
Old 08-15-2013 | 12:34 PM
  #2173
darkstar1974's Avatar
Hey Danny,
Just ordered a few shorty packs from you and was curious which power supply you're using for the PL8. I'm currently using the Hitek X4 and agree with you. It's cool to charge 4 at once, but the 6 amps is just too slow. I'm in between the PL8 and the Hyperion 720 Duo. I like that the Hyperion can put out 2 x 500 watts. I run 3 classes usually and the ability to charge 2 packs at once is a nice option.
Thanks.
darkstar1974 is offline
Old 08-15-2013 | 12:46 PM
  #2174
mxgregg's Avatar
I just bought a HP server power supply off of Ebay for $50. Puts out 47 amps and 575 watts for my PL-6
mxgregg is offline
Old 08-15-2013 | 02:01 PM
  #2175
kjohnsiii's Avatar
I love my power lab! I run a lot of classes at big races and it keeps up, I use to need two chargers.
kjohnsiii is offline
