Spektrum
Old 04-04-2006 | 12:48 AM
  #1396
Ray Murray's Avatar
Wow, that's HOTTTT!!!!!
Thanks G Ace......you ROCK BRO!!!!!
I just got on the spektrum bandwagon and need extra receivers, so I guess I'll hold out for these little gems.....
Ray Murray is offline
Old 04-04-2006 | 03:02 AM
  #1397
ttso's Avatar
Is this telemeter on servo?
http://sudacolumn.cocolog-nifty.com/...s/P1030946.JPG
Source: http://sudacolumn.cocolog-nifty.com/...2006_ceef.html
ttso is offline
Old 04-04-2006 | 07:10 AM
  #1398
Ultraspeed84's Avatar
so is that a reciever then or is that the piece for the spectrum telemetry? Because i want one if its the reciver the cars now days have zero room...
Ultraspeed84 is offline
Old 04-04-2006 | 07:54 AM
  #1399
G Ace's Avatar
The picture I took was the ENTIRE RECEIVER.
It appears that the new micro receiver uses the same molded case as the telemetry add-on unit, so I am sure people will mistake the new RX for the telemetry TX module. If you notice on the pictures I took, there is an antenna wire coming out of the top right corner of the case that is not on the telemetry module in the picture of the touring car.
In place of the button on the receiver for binding, there is a special "jumper" plug that comes with the receiver that is a Futaba J plug with a wire that runs from the white to the black lead. You have to plug the jumper into your 3rd channel while binding the receiver.
G Ace is offline
Old 04-04-2006 | 08:39 AM
  #1400
Boomer's Avatar
that makes complete sense!!!
Why have a button on top for something that you're only (supposed to be) doing once (or once in a great while). . .the jumper idea is great!! Especially if they provide it, although it should be NOTHING to make. . .
thanks!
Boomer is offline
Old 04-04-2006 | 08:52 AM
  #1401
Scarab's Avatar
Does anyone know if the DX3 has exponential and I'm just not finding it?
Scarab
Scarab is offline
Old 04-04-2006 | 09:08 AM
  #1402
G Ace's Avatar
thanks!
The jumper comes with the receiver, it was just a servo plug with a little loop of red wire on it.
I thought it was an awesome idea too, because not only should you never have to bind the receiver once it is done correctly, but also you don't have to worry about somebody or something accidentally pressing the button.
G Ace is offline
Old 04-04-2006 | 09:58 AM
  #1403
F1 Nutter's Avatar
Scarab
The DX3 unfortunatly does not have exponential.
F1 Nutter is offline
Old 04-04-2006 | 01:01 PM
  #1404
2-Bad's Avatar
That's a shame... I like the button, because I swap between my buggy, truck, and tourer, from week to week, and sometimes during the weekend. A button is just a little more convenient for me...
2-Bad is offline
Old 04-05-2006 | 08:29 AM
  #1405
Tubaboy's Avatar
You shouldn't have to rebind just because you're switching cars. Multiple receivers can be bound to the same transmitter module.
Tubaboy is offline
Old 04-05-2006 | 12:43 PM
  #1406
They do if you want a different fail safe position
au_Nightmare is offline
Old 04-05-2006 | 01:48 PM
  #1407
PitCrew's Avatar
Here is the WORLD EXCLUSIVE first picture (I think).
I am capturing the video right now, I will try to grab a couple more screen shots of it in the car.
Before anybody asks, that is correct, it does not have a setup button on it.
Not that size is much of an issue with 1/10 scale, but do the micro receivers work for 1/10? Are they the same processing speed and all that?
Are the specs similar to their PRO version?
PitCrew is offline
Old 04-05-2006 | 02:02 PM
  #1408
JSJ Racing's Avatar
I've got one for you. When working on my car with my transmitter and esc turned on. If I set my radio within six inches of the receiver the receiver goes into failsafe. When I move my radio away the receiver turns back on. Move radio back goes into failsafe. Anyone else have this problem.
Not bashing, I love my Spectrum System.
JSJ Racing is offline
Old 04-05-2006 | 02:13 PM
  #1409
Can the electric telemetry unit be used with the DX3?
AChupp2 is offline
Old 04-05-2006 | 03:33 PM
  #1410
G Ace's Avatar
The transmitter module Andrew was using in his EX-10 transmitter appeared to be the SM1001 DSM Pro Series Module with the translucent case. So it should be the same specs as the "Pro" receiver, and it could be used in any scale car, not just mini/micro cars. My guess is that this will probably replace the larger receiver that currently comes with the "Pro" system.
G Ace is offline
