Spektrum
Old 02-25-2008 | 02:41 PM
  #2506
RCGaryK's Avatar
Originally Posted by Rainey
Ok ... I need help. I have used Spekrum in all of my cars/trucks in the past and now I am setting up my T2 008 with a mirco (3500) and I am having no luck. I followed the instructions to bind to my transmitter and after 20 attempts it still isn't binded. I made about 3-4 attempts with everything like it's going to the track. Then I unplugged the fan on the GTB thinking it might be interfering. No luck. Next I unplugged the PT. Still no luck. I then unplugged the steering servo. No go. I moved away from any cellphones, tvs or anything that might be causing a problem. No luck. I do have a fully charged battery, the bind plug is in the bind (B) slot. Nothing. I have never had this problem before so not sure what to do, but this is my first adventure with the micro receiver.
Any ideas?
Mark w
Reverse the polarity of the plugs going into the receiver. Try this and let me know if it works. This is a VERY common mistake
RCGaryK is offline
Old 02-26-2008 | 05:58 AM
  #2507
Rainey's Avatar
ummmmm... thanks, that did the trick.
Funny how sometimes the smallest (simplest ) things skip right past you.
Mark
Rainey is offline
Old 02-26-2008 | 06:35 AM
  #2508
RCGaryK's Avatar
Good to hear that's all it was. For some reason that's a very common mistake with the 3500. That means others made the mistake before you did
RCGaryK is offline
Old 02-27-2008 | 09:08 PM
  #2509
aussies1129's Avatar
Originally Posted by aussies1129
hi would anyone know if the antenna wire plugs into J1 or J2 on the board for the sm1000 module?
cheers
whats going on does nobody know the answer to this question??
I just want to thank everyone for answering my question, isnt it great when you work it out for yourself??and no I am not giving the answer out
aussies1129 is offline
Old 03-17-2008 | 05:36 AM
  #2510
tried searching around.....but found no real answer. What is the difference between the DX3 and DX3.0? I know ones newer then the other, but other then that whats so different? And why is the DX3 preferred over the DX3.0?
Baedarlboo is offline
Old 03-17-2008 | 06:59 AM
  #2511
RCGaryK's Avatar
The DX3.0 is the newer radio between the two. The DX3.0 has Exponential rates and I believe the DX3.0 has 4 model memory where the DX3 is only 3. The DX3.0 also has a dual-rate override button. The DX3.0 also has a little nicer display and enhanced ergonomics too. This is all off of memory but I would suggest checking out the product pages for each.
Now if you're talking the DX3.0 VS the DX3R that's a different story. There are a number of differences between those that I can go into if that's what you mean.
RCGaryK is offline
Old 03-17-2008 | 07:22 AM
  #2512
Scottrik's Avatar
The crawlers like the DX3 because of the manner in which the 3rd channel is switched on/off in either direction. This works very well for utilizing a "dig" function (connecting/disconnecting rear driveshaft), operating a winch servo, etc.
For any other purpose the DX3.0 is a superior radio. I've got both.
Scottrik is offline
Old 03-17-2008 | 07:24 AM
  #2513
Thanks for the info, I did mean the dx3 and not the dx3r. Info on the dx3.0 and dx3r are plentiful, just seems the dx3 info and comparison was hard to come by. Good info, thanks.
Old 05-11-2009 | 01:03 PM
  #2514
TheeMikeCee's Avatar
I have the KO Propo Helios with the Spektrum module. Over the weekend after I turned the car and radio off, the reciever and module would unbind itself. It was intermittent. The beginning of the day it would do this, then after I re-binded it several times, it was fine the rest of the day. Anyone know whats goin on? It has the spektrum mod done to it if that matters. Iam using the SR3000 reciever.
TheeMikeCee is offline
Old 05-13-2009 | 08:18 AM
  #2515
tunerjetta29's Avatar
Interesting, I have a similar problem with my helios/sr3000. It wont completely unbind. But after about an hour of use the car starts to glitch out. There is no problem with the components, wiring, nothing. A simple re-bind solves the problem for another hour of run time, then again the same problem. Gets frustrating.
tunerjetta29 is offline
Old 05-14-2009 | 12:02 PM
  #2516
So?? Anyone?? Maybe I need a new Spektrum Module??
Old 05-14-2009 | 03:33 PM
  #2517
does spektrum fix bad receivers? ive had one on my slash and just noticed if i turn left and right like crazy it will cut off??!?!? and evryone who has a slash know their is a nice water proof receiver box. my receiver has never seen dirt or oil.
midship909 is offline
Old 05-14-2009 | 04:31 PM
  #2518
Spektrum (Horizon Hobby) has a pretty good repair/replacement policy. I think they've got a handful of downloadable forms online, mail it in with a good description and they will likely send you a new one.
adam lancia is offline
Old 05-14-2009 | 04:35 PM
  #2519
You have to send it to Horizon. Download the service sheet and give an explanation what is happening. I did this with my sr3000 as it was intermittantly glitching and losing signal for me. They couldnt duplicate the problem so they sent me a brand new sr3001. They didnt even charge me to ship it to me either.
Old 05-14-2009 | 04:41 PM
  #2520
thanks guys for the 411
