Help me pick out my dream charger and power supply setup!!
#16
No different to any other charger in theory
They offer 2 safe parallel setups where they use polyfuses as a safety item when connecting packs at a different discharge state (voltage)
1. Daisy chained balance boards, you connect a pack to each
2. New MPA Parallel adapter board
Both are explained on their website
Cheers
Cheers
Thanks!
#17
Charge rates
5000mah sized pack
1c charge rate = 5 amps / 1 hour
2c charge rate = 10 amps / 30 minutes
5c charge rate = 25 amps / 12 minutes
Parallel you simply add the pack capacities
2 x 5000mah sized packs
10000mah total
1c = 10 amps
2c = 20 amps
Charger power requirements
2s pack
5 amps x 8.4v = 42 watts
3s pack
5 amps x 12.6v = 63 watts
Generally speaking your power supply will be rated 20% higher than your charger
1000 watt charger = 1200 watt power supply
Charger manufacturer will list the voltage and current requirements to reach full output of the charger
Read this website for basic info
http://www.tjinguytech.com/charging-how-tos
Cheers
5000mah sized pack
10000mah total
1c = 10 amps
2c = 20 amps
2s pack
3s pack
Cheers
#18
http://www.amainhobbies.com/product_...ger-w-Balancer
Are the batteries that come with the car capable of higher charging rates?
#20
I'm having a problem with the cellpro right now and determining which type of balance plug I need.... I dont know what kind is the normal 3-pin white plug that I have on just about all my batteries. Its the standard plug on my Venom and Sky Lipo batteries... Is that the type of plug that comes on this cellpro balance board? http://www.revolectrix.com/MPA_XH.htm
The next set of batteries I'm buying will have bullet connectors so I can change to whatever I want at that point.
Ok now I need a power supply. That charger is ordered up woohoo! Can someone point me to where I can score a good power supply setup?
#21
Charge rates
5000mah sized pack
10000mah total
1c = 10 amps
2c = 20 amps
2s pack
3s pack
Cheers
5000mah sized pack
10000mah total
1c = 10 amps
2c = 20 amps
2s pack
3s pack
Cheers
#22
JST-XH is pretty much the industry standard for balance leads, with a few using something else
Power supply is going to cost you more than the charger itself unless you build / modify one yourself
This guy sells modified computer power supplys
http://www.feathermerchantrc.com/
This one as pretty damn good from Amain
http://www.amainhobbies.com/product_...-30V-40A-1000W
Cheers
Cheers
#23
I'm looking at the modified computer supplys right now crusey. I found a user that I think builds them. I'm going to either buy one or build one myself, and build a case out of something and install the supply and mount the PL6 with the balance board and just have one big charger haha. Pretty excited about this, now to start ordering up the batteries
#24
yes the MP board now runs JST XH which is the most comon connector availabe....Hking, Venom, TPower etc etc etc. We think 90% of yu guys are running this and even REVOLECTRIX packs when bought online have this option for selection too
#25
#26
[QUOTE=Tombsy;10145204]Another vote for the PL6, I just picked one up before Christmas along with a 24v power supply from Maxamps. It all fits nicely into a Rubbermaid toolbox.
If you Google "portable charging stations" there are some nice setups the heli guys have made.
very nie set-up brian....i like the safety cable holds on the left.
Nice touch
Nice touch
#27
PL6 is on order, waiting impatiently haha!
#28
I have a new question. How does a 24v vs. 12v power supply relate to charge rates and is it even usable in certain situations? I look at the mathetical equations and see no reason why I would need a 24v PSU.
So how does voltage effect the equipment and charging capabilities?
#29
Some chargers require a higher input voltage to get maximum output
If you supply them with a lower voltage their output will be limited
The manufacturer (spec sheets) will tell you what voltage and current is required for full rated output
My charger for example (Icharger 206b)
12v input = 220 watt output
15v input = 280 watt output
Cheers
Cheers
#30
Looks like I'm going to go with the maxamps power supply. Torn with either the 12v or the 24v. I'm thinking the 12v will probably be more than enough for my needs... but the 24v is screaming my name haha!
Charging 6 batteries at the same in like 20 minutes just gets me excited, is there something wrong with me? hahaha!
