calling all FUTABA 3PK users.....
#737
hi guys, gud morning, i purchase a futaba 3pk 2 weks ago, tried to use it on my tam tnx but it wont work on my throttle. when i start the tx and follow d' rx its normal, both steering and throttle but after a few seconds when i start to move the steering, my throttle automatically brakes and thats it, won't move my throttle anymore only d' steering is normal. i only use level 1 for beginners. appreciate all response. many thanks and god bless.
androidz77
androidz77
#738
yes, i already replace it wid new one but still the same. by the way i'm using the HRS mode and all my servos are not digital, is this will affect the problem? thks man.
androidz77
androidz77
#743
I charge mine at .70 amps, but if I am in a bit of a hurry. I will bump it up to 1.0 amps. I am afraid what 1.5 amps will do.
#744
Guys I need some help here please. I bought the 3pk tray to place 8 AA batteries on and want to know how do you place it in the radio and be able to close the lip?? I try to place it in the radio but it looks tricky can someone show me with a pic please I do not want to force it in and mess up the radio??
Felix
Felix
#745
Felix
Felix
I'm not sure i completely understand why you're having trouble but i'll see if i can help.
The rubber insert where the stock nicad pack went obviously has to come out, and place the battery tray in so the batteries are facing OUT.
The lid should fairly easily slide over and close, just watch the battery pack wire just before the lid secures.
i'm not sure that was much help, let me know if you're still having trouble.
Jon
#746
Felix,
Jon
Jon
#747
got it one needs to place the tray on its side with the wires are and then drop it in..
Thanks for your help.
Felix
Felix
#748
reseting model in radio leaves outoput on servo channels
I have a problem with my 3PK, it is an older one, golden in color.
When I do a model reset to reset every setting in the radio,
usually one of the servo channels stays with output
the other day it was channel 2 that had lots of brake applied after the reset.
I can not get this removed from the radio????
inputs?? what can be wrong?
Am I in for a new radio?
Thanks!
/Johnny
Thanks!
/Johnny
#750
Has any one else noticed there's been a change in the trigger on the 3PKS.
I was at a hobby store today and they just got in a new 3PKS. The trigger on it was much tighter than on previous 3PKS. It had almost no gap when your finger was in, and no need for fuel tubing or bending. It was amazing.
Everything else about the radio was the same.
Maybe JonnySocko has more info.
