calling all FUTABA 3PK users.....
#721
I have a 3pk with HRS receiver and trying to set up a Mamba max speedy with no luck. It is like the switching rate is too quick and unable to run through the set up. I have tried running it in PPM mode and still no luck. Looking in the instructions it says to use a DSC cable for non futaba speedys is this right.
If anyone can help with this or has gone through the same problem I would be most apreciative for your help
#722
You cannot run HRS in PPM mode so dont bother...
Im assuming your running a digital servo? (hrs will not work on analog servos)
Im not familiar with the mamba but what exactly is not happening?
Try the DSC cable but its main purpose is for use at races where you are not allowed to transmit a single from the pits so the cord is used as a direct link.. It should not matter but give it a try anyway.
Are you sure all your throttle settings on the 3PK have been zero'd and maxxed?
before doing your setup?
#723
I am using a digital servo and that is working all fine,
It is when going into the speedys set up mode and trying to do the neutral, throttle and braking set points. It is not picking up the neutral point to allow you to move forward in the set up.
I have tried the speedy with another radio and it is working fine, so I dont think that is a problem. I have done a model reset back to factory settings on the radio and EPA and curves on the throttle are set at 100%
#725
I have been using the 3PK since its inception. I need the functionality for my 1/5 scale. I recently switched to LiPo's and it has been one of the best things I have done. For years, I have ran the 2200 NiMH cells and just plug the transmitter in to charge it. I have never really gotten past 11.9 volts and by the end of the race day, I have less than 10V. I have dealt with it for a long time with no issues. I just leave the transmitter plugged in.
Now with the Common Sense LiPO pack, I have 12.5V indicated on the 3PK and over the course of 2 days of racing and practicing, the voltage has only dropped to 12.4. Very impressive. The weight of the pack has also decreased the overall weight of the radio and its balance. IT will make a big difference for the 30 minute mains we run in 1/5 scale.
#726
#727
Hey guys i've been running a 3pks for about a year now and have noticed that all my friends with the same radio have much more physical throw on the wheel. When i go into the menu and go to the adjust option my left and right barely hit 70%. I have adjusted it so that 70% is full throw and confirmed that by making sure the servo is turning the wheels all the way. Has anyone else seen this? my friend checked his in adjust mode and it hits about 115% in both directions. Any input would be appreciated.
Jerry
Jerry
#728
Not sure if you guys can answer this question but here goes:
I'd like to know if I can use my Spektrum modules in the 3PKS with the part number "FUTK2010 3PK Transmitter Only"? This is how it's described on Futaba's website. In other descriptions I've seen they talk about a synthesized module that is included. So I'd like to make sure that my modules from the original 3Pk will work with this part number. I broke the LCD screen on my current 3PK and I don't think it's worth the repair since they've upgraded to the 3PK-S.
Thanx in advance.
Thanx in advance.
#729
Jerry
Jerry
#730
Has any one else noticed there's been a change in the trigger on the 3PKS.
I was at a hobby store today and they just got in a new 3PKS. The trigger on it was much tighter than on previous 3PKS. It had almost no gap when your finger was in, and no need for fuel tubing or bending. It was amazing.
Everything else about the radio was the same.
Maybe JonnySocko has more info.
#731
The wheel on the radio doesnt go as far. for this example i will make up numbers because i didnt measure how many degrees it goes. Lets say my wheel on the radio goes 20 degrees in one direction. Every one else goes 35 degrees in one direction. so their radio wheels go 50 percent more in one direction.
#732
hey guys, just want to know where to get the best price on a 3pks with fasst system on the net? thanks.
#734
Jerry,
Is this the stock wheel? Have you installed an aftermarket one? Has the wheel ever been removed from the radio? The stops on the inside of the wheel are what decides the end point of the wheel travel. Did you buy your radio new or second hand?
Jon123,
Yes the trigger is different, no you can't buy it separately, sorry.
Socko
Jon123,
Socko
#735
hi guys, gud morning, i purchase a futaba 3pk 2 weks ago, tried to use it on my tam tnx but it wont work on my throttle. when i start the tx and follow d' rx its normal, both steering and throttle but after a few seconds when i start to move the steering, my throttle automatically brakes and thats it, won't move my throttle anymore only d' steering is normal. i only use level 1 for beginners. appreciate all response. many thanks and god bless.
androidz77
androidz77
