HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#5956
I did mine this weekend. Upgraded the LCD box first. Make sure you pick the Program card from the drop down like Cobra said, and update it again. Then pick the esc from the dropdown, and do the esc firmware, and reset your end points.
If all you want to do is adjust what you have, plug it in to the fan port only, connect battery, then turn the esc on, the LCD will power up, when it boots up, hit any button, and make your changes.
I upgraded it to the V1 .11 for the program card and now theres just a butch of square things on the screen . So i cant see anything on it il just need to do it on the PC.
But i did change some settings with it pluged into the PC on the ESC and it took it fine .
#5957
I got it fixed now thanks for your guys help !
Now after i change some stuff on the programming card or though the PC i do have to reset the ESC manually right ?
#5959
Ok yea i did reset it with the set up button and the setting changes i did were still on there .
However i did add 0 timing and i know from the BH ESC it would flash(Blinky mode) with no throttle i guess the SCT PRO is diffrent ?
And the 130814 filmware for the ESC how do you do that i tried to but it was just highlighted blue i couldnt add it.
#5960
Wondering if anyone can provide guidance around connecting a smaller wire gauge motor to a mamba monster with larger wire gauge?
Seems like the best way would be to take the HW motor wires and solder them to a castle connector. Any better way to do this or recommended methods...pictures would be great!
Thanks!!!!
Thanks!!!!
#5962
Anybody know ?
#5963
Could anyone share what battery you guys are running with the SCT Pro/4700KV combo in the Losi SCTE? Trying to help a friend get going and I know little to nothing about 4wd SC trucks. He will mostly be racing on a medium sized outdoor tracks but may venture to some larger tracks down the road so I would like to get him some advice on a good all around battery that will adequately power the truck on most any track.
Would a 40C 6500mAh be adequate?
#5965
#5966
That's the same firmware I installed in mine. Went right in. Is your LCD card updated to the latest? You have to have the laptop hooked to the card, and the card hooked to the ESC fan port. Switch on. And make sure in the software you have the esc picked not the card.
#5967
I am new to brushless and sensored, and ordered a Speed Passion Competition MMM 10.5 motor today. I am trying to figure out which Hobbywing ESC I should pair up with this motor. I will be using it to race in a short course 2wd. I didn't know if I should use the 150A EZRUN, 150A XERUN, or the XERUN SCT Pro.
Also is the programming card included or is it bought separately?
Is it necessary to have?
Anything else I will need to purchase?
ALSO what C rating of Lipo should I run with this setup?
Thanks for helping a newbie!
#5969
Paul
