Havok 3S Error Code
Old 03-12-2011 | 05:55 PM
TKeller's Avatar
Default Havok 3S Error Code
Hello All,
Maybe someone has seen this before. I purchased a new Havok 3S with Balllistic 17.5 combo. I ran it for the first time last weekend. Up until the Main I had no issues. When running in the A-Main (I tq'd) the truck shut off at about the 7 minute mark. I had a flashing code I thought was a motor overheat. It turns out the code is some type of continuous error. I get the RED and AMBER lights flash together twice and the the Red flashes once. The speed controller will allow me to do the onetouch reprogram but will not allow me into the custom modes. It is connected to a 2s Lipo in a Losi SCT. Any help would be appreciated.
TKeller is offline
Old 03-12-2011 | 08:40 PM
does this help you out, looked over at the novak site for info
ERROR CODE S
The Havoc 3S ESC is equipped with internal protection. The following is a list
of error codes depicted through LEDs––most flash when throttle is applied.
• All status LEDs scroll from left to right––Check blue sensor harness wire
for disconnection or motor does not have temperature protection. For proper
operation, replace blue sensor harness wire or motor with temperature
protection. Check Novak Web site for motor compatibility list.
• Red & Green status LEDs on solid––Check input signal harness
connections at ESC and receiver. Check input signal harness wiring
sequence––Refer to Step 1.
• Red & Green status LEDs alternating––Li-Po Cut-Off triggered—Replace or
charge battery. Incorrect battery selection or battery voltage may be too low.
• Red status LED on solid & Green LED blinking––Check motor sensor
harness connection. Possible internal motor damage.
• Blue & Green status LEDs both blinking—Possible ESC shut-down due
to locked rotor detection––Return throttle to neutral position to regain motor
control––Check vehicle’s drive train for free operation.
• Blue & Red status LEDs blinking—Possible ESC thermal shut-down—
Check gear ratio & free operation of drive train for possible overloading/
ESC is being severely over-loaded––allow system to cool & return throttle
to neutral position to regain motor control. LEDs will continue to blink until
system is cooled down.
• Blue & Amber status LEDs blinking—Possible motor thermal shutdown––
overloading/motor is being over-loaded––allow system to cool & return
throttle to neutral position to regain motor control. LEDs will continue to
blink until system is cooled down.
• Blue & Green (Locked Rotor Detection), Blue & Red (ESC Thermal
Shut-Down), or Blue & Amber (Motor Thermal Shut-Down) status LEDs
blinking—ESC may have shut-down & ESC’s neutral point is too far off to
sense that transmitter throttle has been returned to neutral—Refer to Step 5.
Troubles Dad is offline
Old 03-13-2011 | 07:04 AM
TKeller's Avatar
Default ESC Troubles
Being the unit is new I did have the troubleshooting sheet that had those codes. Novak's site doesn't mention any additional codes. Thanks.
TKeller is offline
Old 03-31-2011 | 05:49 PM
Hi, I'm having the same issue. Red and amber flash and motor cuts out for 4-5 seconds and then starts again. Timing can be random. Ran slowly in back yard this morning so overheating isnt an issue.
4theboy is offline
Old 04-01-2011 | 09:39 AM
Company Representative
What receivers are you using?
[email protected]
NovakTwo is offline
Old 04-02-2011 | 03:15 PM
godofcable's Avatar
Novaktwo- I am having a similar issue. In my case, i lose all power. When I ask them to the friendly marshals turn it off then back on, and it runs fine for the rest of the race.
I am using a Traxxas Link 2218 receiver
godofcable is offline
Old 04-03-2011 | 07:43 AM
Default Information for Tech Support
Many times the problem you are experiencing will have an easy fix and you will not need to return your product for service. Unless you include the info below, we may not be able to assist you by email. Please email [email protected] with your questions, or contact [email protected] Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used, quality of soldering
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim? Include serial numbers
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: crash damage, water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance; without this information, diagnosing your problem, without seeing your item, is practically impossible. You can PM me if you want additional CS assistance.
NovakTwo is offline
Old 04-03-2011 | 06:00 PM
TKeller's Avatar
Default Thanks
Thanks for the response. I have sent a e-mail to Tech Support. If Novak has a fix. I will post it here.
TKeller is offline
Old 04-13-2011 | 06:24 AM
TKeller's Avatar
Default ESC Trouble
In my case the code was an issue with the main board on the ESC. The unit was actually rebooting itself. The folks with Novak Tech Support are fnatastic to work with. If their products are as good as their tech support I will be sold for life. Thanks NovakTwo.
TKeller is offline
Old 04-29-2011 | 04:21 AM
Was wondering how the problem was resolved? Thanks.
boobie817 is offline
Old 04-29-2011 | 06:34 AM
daverobbo5's Avatar
All these esc's are faulty/crappy timewaters
do a search for ' problems with novak's havoc" and have abox of tissues ready. there are heaps of threads about these expensive throw aways.
They stall and glitch for heaps of users.
I had to ebay 2 of these as faulty for the limited value of the motors alone.
don't waste your time explaining to novak that you want to vary the voltage from the battery to the motor like nearly hundreds of companies can do better for less money and wasteded time at the track. it's called a working esc
change to better product!
daverobbo5 is offline
Old 05-12-2011 | 12:46 AM
mojoman81's Avatar
Thumbs down
i just got this too i ran for about 10 min and it shut down .Now I have flashing amber and red flashing lights and it resets itself. This will be the 2nd time i have to send this setup back.
mojoman81 is offline
Old 05-14-2011 | 06:03 PM
daverobbo5's Avatar
I''m just searching my HD to find the list of threads I compiled about crappy Novak s(p)eedies.
I do it to encouage orange power to remember they were once a great American pioneer but now producing trash worse than the cheapest Chinese fudge.
Novak own up, man up recall the stuff you know is crap and come back and join the rest of the R/C world making servicable speedies.
Old 05-18-2011 | 02:06 PM
daverobbo5's Avatar
http://www.rctech.net/forum/radio-el...-problems.html
http://www.rctech.net/forum/electric...-problems.html
http://www.rctech.net/forum/radio-el...ir-update.html
http://www.rc-monster.com/forum/showthread.php?t=27013
http://www.hobbytalk.com/bbs1/showthread.php?t=277472
http://www.rcuniverse.com/forum/m_10...m.htm#10043491
http://www.youtube.com/watch?v=zHnxNe_BwwU
http://www.rc10talk.com/viewtopic.php?f=40&t=14538
http://www.rcshortcourse.com/forum/s...ad.php?p=98222
http://www.daddyhobby.com/forum/showthread.php?p=449833
http://www.rctech.net/forum/electric...oc-issues.html
http://www.rctech.net/forum/electric...tting-out.html
http://www.rc10talk.com/viewtopic.php?f=40&t=10960
