Speed Passion Thread >
Like Tree4Likes
Old 12-20-2014 | 02:04 PM
  #5281
Also I just ran it for a second and noticed the motor has a sorta a metallic ringing noise at full throttle... Normal?
NewbieRacer30 is offline
Old 12-22-2014 | 11:32 AM
  #5282
Originally Posted by Brian C.
Hey guys I had one of their speed controllers and it fried in 50ft how is their repair service? If anyone know that would be great, for some reason I couldn't find a way to contact them on their mobile site... Thank you!
If it's still under warranty go to the main website and fill out the RMA process.
Are you just revving it on a car stand with no load?
Nexus is offline
Old 12-24-2014 | 02:09 AM
  #5283
Hey guys I am about to install a prevention pro 1.1 in a TLR scte 2.0 corr truck. I got a blaze 4600kv motor for it. How do they run?? How do u guys have them setup with the program box??
S.TRIPP77 is offline
Old 12-27-2014 | 12:35 AM
  #5284
Anyone?????
Old 12-27-2014 | 04:39 AM
  #5285
Anyone?????
I've run that speedo. In my opinion I like all there speedos. The one tack I go to there is a guy that's helped me setting them up. I think he runs for them. His a TLR guy. And runs the 17.5 classes. Which is all about speed and smoothness. So I'd say you can't go wrong with it.
When is there 17.5 motor coming out????
Rcfun96 is offline
Old 12-27-2014 | 10:51 PM
  #5286
JeepnMike's Avatar
I just bought a Reventon Pro 1.1 and ran it for the first time a few days ago (4WD MOD buggy). From acceleration, to brakes, I like it better than the Tekin RS Gen 2 in my 2WD car, and I like it better than the Tekin RX8 in my 1/8 buggy which I really like. Figuring out the software and firmware and how to get it into the ESC and program box required an hour of toggling around and mild irritation. My main issue there was getting the right software version into the ESC to get reverse to work. Once I got that part figured out and got all of my settings to how I like them, it was beauty. The application you load on your computer to communicate with the ESC could use a bit of work and isn't as intuitive as the Tekin Hotwire software, but it gets the info into the ESC and gets the job done for likely 95% of the users out there.
The ESC has a small footprint for as powerful as it is and looks really well built. Aesthetically, it is awesome. I was so happy it performed as well as it did, making it a hell of a deal for how well it performs. It fills a niche between Trackstar Hobbyking stuff, and high dollar Tekin or Orion stuff. For my tastes, it actually works better than the high dollar stuff I currently have though.
JeepnMike is offline
Old 12-27-2014 | 11:15 PM
  #5287
askbob's Avatar
Haven't checked in awhile but does the newest version of Apple ios work with the wireless connection using the Reventon Pro?
askbob is offline
Old 12-28-2014 | 09:27 AM
  #5288
JeepnMike's Avatar
Nope. Just like Tekin, it is Droid only. The guys at Tekin have said it is a major @#$#% to get Apple to play nicely with this stuff.
Old 12-28-2014 | 12:28 PM
  #5289
Just got a reventon pro in trade and have a couple questions.whats the difference in mine and the 1.1,also what firmware would be good to use in 2wd and 4wd mod buggy also do I need a fan installed.thanks
xxxntwv is offline
Old 12-28-2014 | 03:09 PM
  #5290
rraden's Avatar
According to Speed Passion the 1.1 has:
-upgraded MOSFET
-internal resistance <0.0002ohm
-improved braking
-lower 30mm fan
I have both and can't tell the difference other than the size of the fan.
Install MOD 2 program for mod buggies and only need to run a fan on the 4wd.
rraden is offline
Old 12-28-2014 | 04:47 PM
  #5291
-upgraded MOSFET
-improved braking
-lower 30mm fan
OK thanks
xxxntwv is offline
Old 12-28-2014 | 06:06 PM
  #5292
Hey S.TRIPP77, I'm running a Revention Pro 1.1 in my TLR SCTE-TEN 2.0. With a Blaze 5700 KV motor. I had no problems with it. I had it in my TLR for a year now.
I run the latest software from Speed Passion website. Speed Passion Revention PC interface V1.1.0.25
I have modified 2 setup in my ESC.
b4wires is offline
Old 12-29-2014 | 09:38 AM
  #5293
There is a V3 and V3 MMM 17.5 currently out. The V4s will not be out until Spring or sooner.
Mainly the FETs are better. I rarely, almost never, see anyone running a fan for 2WD. Indoors you can get away with no fan as well in the wheeler. Some do run a fan, but depending on the conditions you won't always need it.
Nexus is offline
Old 12-30-2014 | 01:15 PM
  #5294
Jdubst13's Avatar
I just got a speed passion pro esc and I'm having trouble getting the esc/program box to connect to the PC interface. I loaded the software a couple times and when I hook it up to my PC nothing happens, what am I doing wrong?
Jdubst13 is offline
Old 01-01-2015 | 08:25 AM
  #5295
Did you download speedpassionUSBport? That might be your problem there.
b4wires is offline
