Like Tree4Likes
Viper RC -
Old 10-06-2014 | 10:54 PM
  #10966
nikos2002's Avatar
Originally Posted by bbischer1
Hey nick i talked to you awhile back in the summer about possibly applying for a sponsorship from Viper, was wondering when i should be sending in my APP.
Make sure the follow our Facebook page -- announcements should be coming this month.
nikos2002 is offline
Old 10-06-2014 | 10:57 PM
  #10967
Originally Posted by nikos2002
If your getting the F and R light alternating -- its a high amp spike error. As bds said it could come from the battery plug moving (causing a small arc), it could also be the sensor in the motor. Its easy to forget that little circuit board takes quite a bit of abuse in side the motor. Along with sensor wire - those would be the big things to check.
Thanks nikos!
Legendary service! Just have to say, love the VTX8 ... prefer it to the RX8 that I had. And the VTX10R-BE hasn't hit the track yet but love it to! Its either the speedo or the motor (D3.5) but it's butter smooth!
WagwanBumba is offline
Old 10-07-2014 | 06:15 AM
  #10968
Cain's Avatar
Tech Legend
Let us know what you think -- your reasoning is valid, look for little RPM difference as well .....
Truggy it is
Tekin technically doesn't want there buggy motors used in truggies anyways and the Tekin paperweight I now have sitting here as the ET48 chassis doesn't give enough room for my Viper VTX8 and Tekin 2000kv Truggy motor without bumping the sensor wire will probably get some lovin in Kyosho's new FO-XX VE, with some viper loving too
Probably a sign the truggy just wants all Viper goodness.
Will sit down I think today or tomorrow and give it a go installing it.
Cain is offline
Old 10-08-2014 | 10:03 AM
  #10969
boborc's Avatar
Nike one more servo question here, would I be better off with a high voltage servo compared to a LV servo. I'm no electrical engineer but when you run a higher voltage doesnt that mean less amp draw which should equate to less heat which we all know is good for electronics. So if I would turn my bec up to 7volton the vtx8 would thatbe better than running it at 6v. Unless there is something different with servos. Thanks
boborc is offline
Old 10-08-2014 | 10:11 AM
  #10970
Cain's Avatar
Tech Legend
anyone here use viper gear for crawling?
reason I ask is that I figure the sensored setup would probably be perfect for it. been toying with the idea of getting one, or, getting that new Kyosho Fo-XX and another VTX8 to drop in
Cain is offline
Old 10-09-2014 | 07:30 AM
  #10971
Yes, and i recently saw they did some crawler specific options like 100% drag brake to hold the truck when off power
Outkast187 is offline
Old 10-09-2014 | 08:07 AM
  #10972
Cain's Avatar
Tech Legend
Cool!
Are there any ESCs from the viper line recommended to use for say the common Axial SCX-10, etc.?
Thinking waterproof a must, so the older VTX10R esc possibly.
Cain is offline
Old 10-09-2014 | 04:39 PM
  #10973
nikos2002's Avatar
All Viper speed controls have the option to choose 100% drag brake -- they have for 4 years.
Also the VTX10R orange and black editions, and VTX8 are all waterproof with the circuit boards covered in epoxy when placed inside the aluminum case.
Don't forget the new Xpert WR - waterproof servos -- available now.
Old 10-09-2014 | 05:27 PM
  #10974
Cain's Avatar
Tech Legend
ah okay. well heck then I may just use the ESC I have sitting here as I was concerned it wasn't waterproof. VT10R-BE Edition
Cain is offline
Old 10-13-2014 | 06:37 PM
  #10975
Motorman007's Avatar
Black Edition or the Orange which is the new one?
Thanx
Motorman007 is offline
Old 10-13-2014 | 06:38 PM
  #10976
Thanx
Black
micrors4guy is offline
Old 10-13-2014 | 06:47 PM
  #10977
Originally Posted by micrors4guy
Black
Thanx sir
Old 10-14-2014 | 09:31 AM
  #10978
tony montana's Avatar
I'm pretty sure I know the answer but going to ask anyways. Is it possible to run the orange vtx10 in a 4wd buggy with a 6.5? I have a r10 trying to fit in a dex410 but I can't get it to fit right because of the size
tony montana is offline
Old 10-14-2014 | 09:41 AM
  #10979
Cain's Avatar
Tech Legend
from what it sounds like, you want the R edition, but I do wonder with proper caps and a fan maybe?
Cain is offline
Old 10-14-2014 | 12:46 PM
  #10980
is this wrong?
Viper VTX10
On Resistance: 0.00045 *2
Support Li-Po Cell: 2S-3S Lipo/LiFe
Max BEC Voltage/AMP: 7V/5A
Motor limit: 2-pole 540/6.5T @2S
Dimensions: 30x32.5x14.5mm
Viper VTX10R
On Resistance: 0.00025 *2
Motor limit: 2-pole 540/2.5T @ 2S
2-pole 550/4.5 @ 2S
Dimensions: 30x32.5x19.5mm
Is he not safe with the VTX10?
