Viper RC -
If its sensored, yes.
On a side note, I raced a lot of dirt oval with 2wd sct, always top 2 in stacked field....so my advice is solid on the subject. That's way too much motor, and you will get killed on the track. There is a reason the pros don't run these oddball set ups...they are terrible. Run a 10.5 motor, and I guarantee its faster on the track...shoot...a 17.5 would be. Been there, tried everything, save yourself the time, money and effort...do what the pros do. Just don't think because they run a 6.5 that you will be fast with one though.
The VTX10R was not designed to run a 4 pole motor. I would be very cautious about even attempting it. Our VTX8 was the first sensored speed control with 4 pole in mind.
Viper VF8 2700kv
Help me out here......
What is the intention of this motor?
On
4S retarded fast/too powerful for racing
Motor over 40.000 RPM can't be good for temps.
I thought these motors were intended for 4S??
On
have had some funny behaviour from my vtx8 today. motor temp cut off is disabled but its been cutting off, usually after a tough landing. f and r lights flash and the p light is red. checked temps but nothing to be concerned about. whats up?!
Got my Viper 1900Kv motor in, feels very quality, looking forward to trying it out.
wonder if I should just drop it in my truggy as if turning the shaft is any indicator I wouldn't be suprised this has more torque than my Tekin 1900.
Of course geared correctly and used correctly, its can be wicked fast - if you have the area needed to max it out.
If your getting the F and R light alternating -- its a high amp spike error. As bds said it could come from the battery plug moving (causing a small arc), it could also be the sensor in the motor. Its easy to forget that little circuit board takes quite a bit of abuse in side the motor. Along with sensor wire - those would be the big things to check.
For racers - slightly harder chance to break gears, as the internal pins that hold the gears in place have less chance to flex (which would cause the gears to lose mesh). As an example our SM series servos use the same all metal core with a metal top piece as well. Break great with that servo you have hit something very, very hard. Trust me -- I have tried!!
4Likes
