Like Tree4Likes
Viper RC -
Old 07-07-2011 | 04:04 PM
  #2131
nikos2002's Avatar
Rick- congrats, nice running!!! Can't believe it was that hot and the motor ran that cool!!!
Eric- if your lap times were good at 140, I wouldnt push it. Maybe just a little more but I try and stay below 150 if it has the speed on the track.
Brian- timing is a bit of a variable, depends on if your running timing on the esc. If not you can put a little in it via the motor.
Good luck to the guys at Hot Rod this weekend. The racing gods owe us one after Andrew's run at the Cactus!!
nikos2002 is offline
Old 07-07-2011 | 04:22 PM
  #2132
Dlewis4's Avatar
R/C Tech Elite Member
Originally Posted by Brian Alderman
Got my 13.5 all set up in my 4.1 and it seems like it will be a runner! It did take a while to get some power out of it though, seems these motors like alot of timing on the MMP at least.
They also need to be geared up....
Dlewis4 is offline
Old 07-07-2011 | 06:15 PM
  #2133
Good to know. Surprisingly, gearing down a bit and adding timing made it run really cool. Only ~115 after the main. It's so low that I'm no longer concerned about it for club racing, but I'll aim to stay below 150 for no-timing Stock races...
Thanks! :-)
EricJ is offline
Old 07-07-2011 | 06:17 PM
  #2134
Thanks, It ran GREAT and it was a great weekend.
bring it on is offline
Old 07-08-2011 | 11:36 AM
  #2135
jkirkwood's Avatar
Is the modified profiles on the esc as smooth as the LRP? Planning on a 8.5 and I don't find the Tekin's I have that smooth running modifieds. Thanks.
jkirkwood is offline
Old 07-08-2011 | 12:03 PM
  #2136
Atmoteam's Avatar
Please tell me how to configure reverse at VTX10R. The car goes in reverse, but after pressing the gas trigger, it is not slowing, but continues to roll back, what's the problem?
Atmoteam is offline
Old 07-08-2011 | 04:27 PM
  #2137
i got my 10r installed and ran it wed. night with a tekin sc5.5 motor. esc felt like it was really smooth and i had a great time. today i got my viper 4.5xl ordered for a big race next weekend. running it my losi scteon a very big outdoor loamy track. any recomandations on where i should start gearing? i know it will vary and i have several pinion choices, but just want to be in the ball park when i start. thanks
nitroal is offline
Old 07-08-2011 | 04:51 PM
  #2138
Default Questions on Viper systems
I'm getting back into the hobby later this summer as our indoor winter program begins. We race on off road carpet set-up in the winter and loomey/hard rough large dirt track in the summer months. I will be running the 17.5 combo in 2wd sc(probly a sc10) Was looking for a explanation on the difference between the VTX10 and VTX10R esc and which 17.5 combo would be more versatile and suit my conditions of racing. Thanks in advance
bbrace3m is offline
Old 07-10-2011 | 12:52 PM
  #2139
itsjusme's Avatar
Vtx10 runs 540 motors down to 6.5 turns.
Vtx10r runs 550 and 540 motors no limit.
The Vtx10 would be enough for stock.
itsjusme is offline
Old 07-10-2011 | 01:43 PM
  #2140
Got to finally race the 13.5 in buggy yesterday at a club race and it ran really well, ended up taking the win. The motor temped cool all day so I think I will take Dlewis advice and add some gear next time even though it was a handfull the way it was!
Brian Alderman is offline
Old 07-10-2011 | 03:02 PM
  #2141
Dlewis4's Avatar
I have only stated it about... oh.... 40 times in this thread
These motors do not gear like anything else out there... they need to be geared up as they have SOOOO much bottom.
Dlewis4 is offline
Old 07-10-2011 | 06:43 PM
  #2142
This was a 20 minute main but at the 6 min mark we had a small dirt devil go throw and lifted 4 easyup's into the sky and we had to stop the race. Sucked because i checked out and was gone. Then we restarted the race and they made it 15 min. I took 2nd but my batt died on the last lap.
Viper 2050kv test motor, 20c truerc battery and Panther tires in my caster 1.5r buggy. It was 90 degress outside and after 15 minutes of non stop racing motor was about 150ish. not bad at all.
Rick Jenkins
Old 07-10-2011 | 06:56 PM
  #2143
7-10-11 As you can see by the results i pulled off the track at the 12 min mark and was in 1st place. There was only 2 e-truggy's so we had to run with the nitro.
caster pro e-truggy, 2250kv viper truggy test motor, 20c truerc batttery and panther tires.
Old 07-10-2011 | 07:25 PM
  #2144
nikos2002's Avatar
Success at the Hot Rod Shootout!!!
Billy Fischer wins Pro 4 SC with his Viper powered Durango
Andrew Smolnik wins 17.5 SC with his Viper powered TQ SX10 SC
pretty sure I saw some other names in some A's that run Viper stuff, but I want to wait until its verified to be sure.
Also want to send a great shout out to Royce Berrio for putting it in 3 A Mains (4wd Mod, 2wd Mod and SC Mod) at the 1st Critters Trophy race in NJ. There were some big NE factory hotshots at the race.
Old 07-10-2011 | 07:32 PM
  #2145
nikos2002's Avatar
jkirkwood - yes you will like the smoothness of the VTX series, its smooth, but you still feel you have control of the power. Some other brands I have used seem to sacrifice power for a smooth feel.
Atmoteam - strange. Almost sounds like it can't find the neutral. Make sure the throttle trim wasn't changed or go through the set up process again and try it. Just a thought.
nitroal - check the Viper Facebook page - Raegan posted some set up info from testing the XL550 motors in his Losi and I think there were gearing notes as well.
