NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 02-29-2016 | 08:47 AM
  #12406
Originally Posted by ta04evah
Updated my Justock to the new 509 No timing software, and I have to admit, the car had a lot more acceleration than it did before.
It was that impressive, that I am considering replacing an older 2.1 Hobbywing esc in my other car with a Justock using the 509 software.
A note to those of you updating. The 509 software is only legal in the XR-10 putting it in the old Juststock, V2's or any other Hobbywing ESC makes them illegal at sanctioned events that require ROAR compliance. It is an easy check, just plug in a programmer.
old_dude is offline
Old 02-29-2016 | 08:58 AM
  #12407
theproffesor's Avatar
How is the software not legal in older ESc's?
theproffesor is offline
Old 02-29-2016 | 10:25 AM
  #12408
RoyB's Avatar
On the Roar approved ESC list it says N/A under software version. For the extreme stock and v2.1 ESCs it specifies 508. It looks to me that 509 is legal in the justock. If not ROAR needs to change its approval list.
RoyB is offline
Old 02-29-2016 | 10:36 AM
  #12409
shortcut's Avatar
When you go to the download page which one is the "509" I don't see any 3 digit designation
shortcut is offline
Old 02-29-2016 | 02:17 PM
  #12410
RoyB's Avatar
Download the 2016 Jan version. I think that the 509 will only load onto justock
& XR10 Justock.
RoyB is offline
Old 02-29-2016 | 02:52 PM
  #12411
shortcut's Avatar
& XR10 Justock.
Thanks, that's what I did, just didn't see 509 anywhere, I have a justock.
shortcut is offline
Old 02-29-2016 | 03:00 PM
  #12412
macdude's Avatar
You need to download the Jan 16 link software. Then when you hook up the ESC it will be in the list of firmware versions.
macdude is offline
Old 02-29-2016 | 03:16 PM
  #12413
RoyB's Avatar
Did you click on firmware update after you hooked up esc?
I have done 2 with no problems.
RoyB is offline
Old 02-29-2016 | 03:31 PM
  #12414
shortcut's Avatar
That's what I did, just don't recall seeing 509.
shortcut is offline
Old 02-29-2016 | 03:50 PM
  #12415
RoyB's Avatar
You must have missed it or your update didn't work.
RoyB is offline
Old 02-29-2016 | 04:53 PM
  #12416
JayL's Avatar
R/C Tech Elite Member
or you may need to update the program box, then update the esc
JayL is offline
Old 03-01-2016 | 04:14 AM
  #12417
You are right about that. I believe ROAR missed this possibility. Oh well, go at it boys (On the Juststock that is).
old_dude is offline
Old 03-01-2016 | 07:58 AM
  #12418
dr_hfuhuhurr's Avatar
Originally Posted by theproffesor
Any update here?
dr_hfuhuhurr is offline
Old 03-06-2016 | 06:33 PM
  #12419
ta04evah's Avatar
Oh thank goodness for that, I had just swapped out my old Hobbywing 2.1 esc for a Justock with the 509 software installed.
One thing I noticed when I had my computer hooked up to the older 2.1 esc, is that there is no option in the drop down box to install 509, the only one that is there is 508. Has anyone else tried to put 509 onto a xtreme stock or 2.1 esc?
I suspect that 509 is locked in to the XR10 & Justock esc's only.
Anyway, replaced a older 2.1 esc with a Justock in a touring car, and I'm impressed. The Justock felt like it gave the car more grunt, and the motor ran cooler, with ambient temperature around 34C (98F?).
And it takes up waaaaay less space than the 2.1
Cheers
ta04evah is offline
Old 03-08-2016 | 08:33 AM
  #12420
13Maschine's Avatar
Originally Posted by COBRARACING
wifi module is complete now the android and ios system being designed so i say about another 6 weeks.
Is the wifi module out yet? Where can I buy it?
13Maschine is offline
