NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
#9631
That would interest me too, if you have a program card, then you can simply test
#9632
#9633
Has anyone tried increasing the cap size on a HW ESC to increase brakes?
I'm using a Justock with V3_508_NO_timing FW in a 17.5 and 13.5 TC and the brakes are horrible. 2 different motor's; 17.5 Thunder Power and the 13.5 Revtech.
I did not have this issue with a Tekin w/223 fw.
I love this ESC but it needs better braking. Any help would be appreciated.
If you needed more you could also try one of the 4 cap boards around if you have room for it.
Actually other hot tip for the Justock, don't upgrade the firmware, it's slower and has less throttle feel, seriously go back to V1-508, also crank the punch to 9 (if the traction is there), dial reverse to 100% (even if your not using it), and bring the dead stick down to 6, all make for a tight feeling $55 ESC.
I'm racing in a field of people with $200-$300 speed controllers, and doing just fine.
#9634
Hi Angelo,
Has the latest firmware update fixed the problem with reverse not working when using Initial Brake = Drag Brake force in Forward/Reverse with Brake mode...the reverse only works if a value is set in Initial Brake Force
V1.64 didn't have this problem but unfortunately there's no going back to V1 firmware once the programmer has V3 firmware installed
If this can't be fixed it would be great to add Custom to Initial Brake Force setting
An android smart phone app would be really cool to be able to program the box at the race
Kev
Kev
#9635
Good morning Angelo,
I sent you a few emails reference payment for the speed control, so I'm trying this medium just encase our emails are having issues communicating.
Milton
Milton
#9636
hey guys I am a newly converted tekin guy now running the v3 with the latest firmware, and am having great succuess in 17.5 and 13.5 blinky touring car. I am currently running the stock settings that come with profile 2. No complaints at all here. One question I do have is that, I do not know what the throttle and brake rate switch points are, nor, do i know what the first and 2nd stage rates are. If anybody could help me out here and explain a little bit more what these settings are and what they do, or how they affect the car and the speed, that would be greatly appreciated.
#9637
[email protected]
#9638
#9639
The Caps dont give you what you guys think is more brakes more caps more brakes not true
The cap board only tries to equalise the voltage of the esc never perfect and the battery also controls ripple current that the motor can produce being a alternating device through to the esc causing heat but that can also be reduce by using a fan always use a fan thats why it is provided a cooler esc means more efficiency = more performance,the rest of the board filters glitches and sometimes if your lucky you might blow the cap board when you reverse polarity the battery to esc and not damage the esc but that all depends how quick you are to remove the connectors thats all it does .
Brakes are features of your own car setup ,track conditions,tyres and software adjustment .
#9640
Hi Angelo,
Kev
Kev
what programmer are you uing hobbywing?Orion?hype? speed passion which one is it ?
Android app we are Discussing now .
we are also inplememnting neutral range for the v3 like the 2.1 has
regards Angelo
#9641
Yes i recieved the email and it was passed onto accounts and they should have sent you out an invoice for the repair .
I will chase it up now
regards Angelo
#9642
regards Angelo
#9643
Angelo, hobbywing has done a forever client on me.
King regards and continue with this great job!
#9645
yes it has been fixed please send me an email and i can forward the file to you for instal.
regards Angelo
regards Angelo
I'll pm you my email Angelo
Kev
