Keyence ESC
Old 12-22-2004 | 12:38 PM
  #271
Default Re: Re: Couple more questions....
Originally posted by Pyramid
I think you should asked Keyence Austalia?
I got it from the USA so I assumed any warranty questions/problems would have to be delt with there?
Mabuchi540 is offline
Old 12-22-2004 | 01:43 PM
  #272
So I'm actually reading the instruction book first and....
As I read it on page 22 it says to complete the function of 1-6 engine braking press the center function button.....
(I assume this is the procedure used to complete each function setting) .....does it then go onto the next function to be set automatically or do you have to push the R button?
Either way (pushing R or automatically moving to next function) on this page it then indicates it will go onto 1-7 energy saving mode...
But according to the diagram of functions on page 30 after 1-6 there is no 1-7 ENSA?
Old 12-22-2004 | 03:10 PM
  #273
L.Fairtrace's Avatar
How should I set up the Rapida Pro for 2wd buggy, so its smooth?
L.Fairtrace is offline
Old 01-01-2005 | 02:14 AM
  #274
Default Re: So I'm actually reading the instruction book first and....
*bump for an answer please* But a bit redundant at the moment (until I get it repaired/replaced) as it died before I got to install it.
Old 01-03-2005 | 08:12 AM
  #275
AdrianM's Avatar
You hit the right or left buttons (either is fine) to go to the next setting. Hitting the center button will get you out of the SET mode. To increase or decrease any given setting you use the trigger, throttle to increase and brake to decrease.
AdrianM is offline
Old 01-03-2005 | 09:30 AM
  #276
Default Cool thanks.....
for the info, just wondering now about the other part of the question please? According to the manual diagram on page 30 ENSA 1-7 doesn't exist after setting 1-6 engine braking?
Old 01-03-2005 | 01:39 PM
  #277
I got a Keyence Rapida-C Pro today, looks awesome.
I thought about getting a KO VFS-1 but opted for the Keyence, mostly beaucause the plug-in wires. Will be super easy to use in my buggies next season.
But, i'm a little confused. Do i have to solder on the noise supression capacitors? Is it really that improtant? My motors have preinstalled capacitors......
Also, is a schottky diode nescesary? Ill probably solder it onto my wires anyway.
Would it be an advantage if i soldered on a powercap?
Anyone got a good setup for stock on a tight, technical carpet track running rubber?
Erlend is offline
Old 01-06-2005 | 09:46 PM
  #278
JayBee's Avatar
Post
I keep trying & trying...
but 'everytime' I try to reset my Key. ZVEtreme I screw it all up and I can't get the damn thing to set up with my transmitter properly. Any of you guys own a 3PK? I know how to navigate through the settings, but the values I set doesn't want to stay put. I have to play around with the throttle just to see if it'll stay where I want it. Once I get the value I want, it counts down back to zero all by itself. HOW FRUSTRATING . Did I already say I'm frustrated ...
- jaybee
JayBee is offline
Old 01-07-2005 | 03:49 AM
  #279
Pyramid's Avatar
Registered User
Originally posted by JayBee
[B]Once I get the value I want, it counts down back to zero all by itself.
As far as I could remember, for transmitter initial setup, those value does not moved. It only move when you setting up the frquency power. But I did remember the Vztreme 2002 is trickier on those 3 buttons than the new rapida-pro in terms of initial setups.
Pyramid is offline
Old 01-07-2005 | 04:02 AM
  #280
Pyramid's Avatar
Registered User
No need until you experience glitches originated from motor. The one from keyence is of higher quality, that is it.
Usefull when using a lot of brakes which is one of a good reason for choosing keyence. The easiest is to solder them on its exposed pcb terminals.
Logically yes, but you might not able to feel it and will take more space as this ESC is small BUT not micro size.
Pyramid is offline
Old 01-07-2005 | 06:45 AM
  #281
STLNLST's Avatar
I run the lowest standard profile and adjust the min. drive freq and the drive freq. It all depends on what you like but I set the drive freq to 1.5 and the min drive to 10-12. I hope this helps some.
STLNLST is offline
Old 01-08-2005 | 01:41 AM
  #282
Default Re: Cool thanks.....
*bump*
Old 01-09-2005 | 03:29 AM
  #283
Unhappy Re: Re: Cool thanks.....
*bump*
No one? Still I guess it's to be expected when you get something not that common.
Old 01-09-2005 | 05:05 AM
  #284
actually this ESC is very common,most people are very intimitaded by it though and it has a false reputation for being hard to set up.It took me a few mins to get the feel for it and it can be aggravating at times.I had to call Keyence on my first one because I thought there was someting wrong with it,But they walked me through it.They have great service also.
Hyper1 is offline
Old 01-09-2005 | 05:26 AM
  #285
Talking Well less common than LRP anyway lol....
so you wouldn't happen to know about the Rapida Pro manual problem I noticed then would you?
