Keyence ESC
Old 05-15-2005 | 09:56 AM
  #421
jeepnyy's Avatar
Whenever I changed the settings, I always save it on another profile in the "program save" menu either on S.P 1 up to S.P 4. According to the manual on page 25.....Program save (only for Zero V Ext)...
When in save display mode, PRESS the left AND right together. LED(7) starts blinking. After that, set the number of the program you wish to save by using either the left or right button. Then press the left AND right buttons together for 4 seconds. When the program loading is complete. "END" will be displayed.....Your DONE !!!!!!!!!!!!!
Happy Racing
Henry E.
jeepnyy is offline
Old 05-15-2005 | 01:13 PM
  #422
wyd's Avatar
wyd
Tech Legend
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
Any place to download directions for the Keyence? I have one but misplaced mine and would like to make sure it is all setup correctly.
wyd is offline
Old 05-15-2005 | 01:29 PM
  #423
JayBee's Avatar
Post
Happy Racing
Henry E.
Thanks for the tip, but that tip doesn't help what I'm trying to fix -JB
JayBee is offline
Old 05-15-2005 | 04:27 PM
  #424
JayBee's Avatar
Smile Re: I'm getting very impatient...
Originally posted by JayBee
with this speedo; I've done EXACTLY what Adrian has said 3 and 4 times to reset my speedo to the TX and once I set nutr, dr_hp, br_hp the values I try to set afterwards does change with the 'squeeze & push' of the trigger but as soon as I'm done, the value immediately goes back to zero This is VERY FRUSTRATING & GODDAMN IRRITATING Is something wrong with my unit or am I missing something? I love the speedo but turning to the dark side is very tempting
Any help/suggestions/tips/pointers guys? -JB
Anybody out there -JB
JayBee is offline
Old 05-16-2005 | 03:50 AM
  #425
KoE's Avatar
KoE
JB, my rapida pro was behaving just like that. i followed adrian's reply to moot and got settled down
KoE is offline
Old 05-16-2005 | 06:28 AM
  #426
So let me get this straight.....
The settings (whatever one you may be trying to set) do go up or down when you push or pull the trigger BUT when you return the trigger to the neutral position the setting goes to 0?
Mabuchi540 is offline
Old 05-16-2005 | 04:25 PM
  #427
JayBee's Avatar
Post Re: So let me get this straight.....
YES, that is correct -JB
JayBee is offline
Old 05-16-2005 | 05:00 PM
  #428
AdrianM's Avatar
The speedo is set to the transmitter incorrectly. The speedo thinks neutral is full brake... thus when you complete a setting and return the trigger to neutral it undoes whatever you just did.
Re-set the speedo to the transmitter.
AdrianM is offline
Old 05-16-2005 | 08:39 PM
  #429
JayBee's Avatar
Thumbs up
Here goes... -JB
JayBee is offline
Old 05-16-2005 | 10:10 PM
  #430
JayBee's Avatar
Post FINALLY...
After playing around with the THROTTLE EXP on my 3PK and setting the throttle & brake to +100, only then was I able to set-up my radio to the speedo. I saved my profile but wanted to see if it really saved my values so I loaded up a default profile and then re-loaded my saved profile. It worked but there's still a problem, the speedo doesn't register any value WHEN I BREAK, but it does when I'm on the throttle. What gives ... -JB
JayBee is offline
Old 05-17-2005 | 04:52 AM
  #431
Jaybee sounds like you've undone your brake setting.
Hyper1 is offline
Old 05-17-2005 | 05:19 AM
  #432
Set all exp's to zero, then reset to transmitter. It really just sounds like it isn't set correctly. It is possible that your transmitter has a setting that is causeing the problem. Might be worth trying to set it to a new model memory on your transmitter.
MattW is offline
Old 05-17-2005 | 04:20 PM
  #433
JayBee's Avatar
Post
How do you think I've done that? -JB
JayBee is offline
Old 05-17-2005 | 04:21 PM
  #434
JayBee's Avatar
Post
I will try that -JB
JayBee is offline
Old 05-17-2005 | 06:37 PM
  #435
JayBee's Avatar
Post Man, this thread isn't...
as popular as it use to be.
However, I did try the zero exp's thing and no, it did not work. But what I did do is reset the model I was using, reset my exp's to 100% and then I HAD AN EPIPHANY- my ATL (adjustable throttle limiter) was always set to zero . This feature adjusts the amount of movement available to the braking side only of the trigger DUH! I've been scratching my head over a month on this. Stupid me. Now I've fallen back in love with my Keyence and livin' in 3PK-speedo bliss.
Thanks guys for all the help ... now I couldn't find my manual but after you set nutr, drHP, brHP and it returns to SET MODE, do you push the center button or the L/R arrows @ the same time to set the frequency settings? I can't remember how I did it, but my settings are there . -JB
JayBee is offline
