whos using XP ds1015 servos?
#35
#37
I've been running the ace 1015's which are the same thing for about 2 years now and have only had to replace 1 set of gears in that time due to an over tight servo saver.
1 thing to watch out for is servo horns, use the ones provided if possible as the spline on the servo is not a true futaba match it is slightly smaller.
if you choose to use a different brand servo horn (or have to use a different brand Ie 808 throttle) then all you have to do is cut a small peice of a plastic bag and press the horn over the top of it onto the spline to take out any slack ,this trick works perfectly.
Adrian
Adrian
#38
futuba horns
#40
1015 for BUGGY Steering is perfect, have only stripped one set of gears due to steering with zero slop and a tight servo saver.
1313 for throttle has good braking force (plenty of torque) and is pretty quick. I could get away with two 1015s or two 1313s, but like to take the best of both worlds for the application.
No issues with ACE / Assoc XP servos so far and I have used and abused four or so for the past year and a half.
#43
I'm using 1015 and 1313 in my RC8 with no problems
#44
I have seen nothing but good things with them and I actually heard that the transit time rating is actuallybeing modest. I hear they are really faster than that. My question is do they have that 1 plastic "saver gear" in them? I want these to be my next servos if I ever need any ever again but if they have that 1 plastic gear I wont like that. I ued to run KO servos and had tons of problems in truggy steering stripping out that "saver" gear so thats when I switched to Hitec.
#45
Yes the first gear is plastic, but it is the third gear that is brass that I have
stripped the teeth off, never the plastic. I had this in a 3.3 Revo and it didn't like it.
I went through 3 gear sets, I have it in my truggy now and have had no problems since.
It seems it was just to strong for the brass it was made from.
Oddly enough I put the ds1313 in the Revo and have had no problems since.
