Nomadio
Old 10-26-2009 | 06:56 PM
  #91
chewiefttc4's Avatar
you guys do realize that these radios run spektrum recievers flawlessly and very solidly.... hmm i wonder if it would talk with the new spektrum sensor receivers.
chewiefttc4 is offline
Old 10-27-2009 | 12:05 PM
  #92
I'll have to have another go at that ... I did it once and remember it being somewhat less than seamless ... the React would bind, but only in beta mode, and I remember constantly having to acknowledge that, and I also think I remember that it was slower than using the Nomadio receivers. Does this sound familiar, or are you able to bind with it just like any Nomadio receiver? If it works cleanly, I should pick up an SR300 ... at just $50, it's much cheaper than the Nomadio receivers, and if you don't need telemetry or that 4th channel, why not save the $35...
JohnPrz is offline
Old 10-28-2009 | 05:09 AM
  #93
Carlos69's Avatar
Default LIFEPO4 RX 6.4V BATTERY
Has any one successfully tried one of these in their React as tx battery?
Carlos69 is offline
Old 10-28-2009 | 06:46 AM
  #94
For the life of me I cannot understand why someone would want to do this when any good NiMh pack in the 1000 to 1600 mah range will run the React transmitter for days.
JVStrat is offline
Old 10-28-2009 | 10:48 AM
  #95
Actually, I find lipos much easier to deal with than Nimh batteries, so when I go to the track, I run mine using a Flightmax 1300mah 2S lipo and a BEC at 5V.
Incidentally, when I switched to lipo I was beginning to notice that, with the power off, my React would drain fully charged nimh packs in a little over a week. It could be that my nimh packs are nearing the end of their lives, nonetheless, has anyone else had this experience? I know ESCs suck power even when turned off, but didn't think radios did. (As a matter of policy, I never leave lipos plugged in when not in use.)
JohnPrz is offline
Old 10-29-2009 | 05:25 PM
  #96
Carlos69's Avatar
I have had near identical experiences to you John, my 3PM's 3s lipo has never missed a beat and doesn't require unplugging after a days racing ... but left in a Nimh in my React will run flat to the point of ruin. It's clear there is current still being drawn by the React even after shut down.
Am curious to know which BEC you use and where u got it ...
Cheers Carl
Carlos69 is offline
Old 10-29-2009 | 05:51 PM
  #97
Hextronic UBEC from Hobby City for $7.
http://www.hobbycity.com/hobbycity/s...idProduct=3735
It's switchable between 5v and 6v, but the 5v setting really outputs about 5.2v, which works perfectly with the React.
JohnPrz is offline
Old 10-29-2009 | 10:04 PM
  #98
Carlos69's Avatar
Thanks a bunch John !
I'll give it a try.
Carlos69 is offline
Old 10-30-2009 | 09:38 AM
  #99
the spektrum recievers are a little slower and yes you have to run them in the beta mode but they are solid and work fine.
as far as the 2s lipo DONT do that without a voltage regulator .. the radios are only meant to run on 4.8 nominal volts.. with a peak of close to six. if you use more than six volts you risk damage to the radio and you void warrenty..
also there is a internal battery that keep the memory running so you dont loose your settings, while the battery is unplugged BUT if you leave the pack plugged in the memory will run off of the main pack instead of the internal battery.. thats why it drains the pack.
Old 10-30-2009 | 10:53 AM
  #100
Cain's Avatar
Tech Legend
I right now run the Nomadio react and use the beta mode for the Spektrum SR3500 receivers I have since there wasn't any tranceivers available at the time. no issues, work flawlessly, though the Nomadio tranceivers do feel a bit more responsive.
Hopefully they don't go away, I really love my React radio.
Cain is offline
Old 11-29-2009 | 06:57 PM
  #101
Victory Side's Avatar
I am not sure if this is a good place to put this, but I have 6 receivers for sale. 70 shipped.
Victory Side is offline
Old 11-30-2009 | 06:28 PM
  #102
Default Nomadio RC is done! :(
[QUOTE=Cain; Hopefully they don't go away, I really love my React radio.[/QUOTE]
http://nomadio.net/nom-react.html
NitroOB4You is offline
Old 12-02-2009 | 01:25 PM
  #103
You guys who are running a React with Spektrum receivers, can you tell me the bind procedure for binding the two. I know to put the React into DSSS mode, but what do I do then?
chiro972 is offline
Old 12-02-2009 | 06:11 PM
  #104
Cain's Avatar
Tech Legend
you will go and bind it just like you do with a tranceiver from Nomadio.
Cain is offline
Old 12-03-2009 | 04:56 PM
  #105
I've had my Nomadio react for a few years and I love it, the product support is great as far as repairs go, I wish they'd offer new products but that work is going to Military Applications, the only radio that comes close to it's abilities is the new spectrums with telemetry, but Nomadio started it first.
rc_racer1 is offline
