Wiring/troubleshooting help ?? >
Like Tree13Likes
Old 11-15-2025 | 09:43 PM
lbsnoopy's Avatar
Default Wiring/troubleshooting help ??
I’ve wired up 2 different brand new tekin rs pro black editions , to 3 different used Sanwa 493’s and a 1up racing fh5 receiver , all 4 don’t power up and both of the tekin esc’s were blinking all lights simultaneously! 4 bad receivers ?? I don’t think it’s a cold solder joint , so what am I missing ??
lbsnoopy is offline
Old 11-16-2025 | 12:01 AM
gigaplex's Avatar
What does a multimeter tell you about the BEC output voltage on the ESC's receiver plug?
lbsnoopy likes this.
gigaplex is offline
Old 11-16-2025 | 02:14 AM
lbsnoopy's Avatar
Default 411
Getting 5.95 v , I have the esc set at 6.0v.
lbsnoopy is offline
Old 11-16-2025 | 02:22 AM
lbsnoopy's Avatar
Default 411
Changed the esc setting to 7.4 and it’s putting out 7.99 . Where do I look now ??
lbsnoopy is offline
Old 11-16-2025 | 02:34 AM
Roelof's Avatar
Steerservo is working? If not try to rebind the receivers.
And did you calibrate the ESC's?
As AI expleins:
A Tekin ESC with all lights blinking often indicates a short in the motor or ESC, a lack of sensor input, or a calibration issue. To troubleshoot, check for a short between motor wires B and C, perform a radio calibration, ensure proper transmitter and receiver binding, and try a different motor. If the problem persists, the ESC may be damaged.
lbsnoopy and gigaplex like this.
Roelof is offline
Old 11-16-2025 | 03:07 AM
gigaplex's Avatar
If it's giving the correct power out then the receivers should be powering up. Are you sure they're plugged in correctly?
gigaplex is offline
Old 11-16-2025 | 04:15 AM
lbsnoopy's Avatar
yea , they are plugged in correctly, I even pulled a 482 off of another car and I didn’t get power to that receiver either . Geez , what are the chances of getting 2 rs pro black editions within a week of each other and they are both bad ?
lbsnoopy is offline
Old 11-16-2025 | 04:48 AM
DirkW's Avatar
Not sure I remember correctly, but I think when the receivers are no yet bound to the radio, he light stays out (I could be wrong about this, though). Have you tried going to the binding procedure nonetheless?
gigaplex likes this.
DirkW is online now
Old 11-16-2025 | 07:52 AM
lbsnoopy's Avatar
Default Reply
can’t bind , no power was going to the receiver , so , I opened up a new gen3 stock spec , wired it up and connected it to all 4 of the receivers and I had power , the car is a go . Just my luck , 2 rs pro be’s , 1 from tekin and one from a eBay distributor, both bad .
lbsnoopy is offline
Old 11-16-2025 | 09:51 AM
Send to Tekin for repair.
hunterdawg is offline
Old 11-16-2025 | 10:40 AM
lbsnoopy's Avatar
Default Reply
I already emailed them .
hunterdawg likes this.
lbsnoopy is offline
Old 11-16-2025 | 01:48 PM
gigaplex's Avatar
I don't see how the receiver is failing to be powered when you already checked that the BEC is providing voltage to the plug. Can you show where you measured and how it's plugged in?
Roelof and hunterdawg like this.
gigaplex is offline
Old 11-16-2025 | 04:25 PM
lbsnoopy's Avatar
Default Teply
Checked positive and negative here .
1 up fh5 receiver installed with the spec esc
lbsnoopy is offline
Old 11-16-2025 | 04:26 PM
lbsnoopy's Avatar
Default Esc’s
Connectors are good on both .  Both are brand new .  Just got the one on Friday from tekin.
lbsnoopy is offline
Old 11-16-2025 | 04:38 PM
lbsnoopy's Avatar
Default 411
Every one of my tc’s has this 13.5 setup with the rs pro black edition, except for one that is mod . The only thing I can figure is the esc’s !?
lbsnoopy is offline
