Amb coaxial clone
Old 08-01-2025 | 04:53 AM
Default Amb coaxial clone
Good morning to the whole forum,
in our 1:10 indoor club, we use the AMB system to time our races.
But the coaxial cable of the decoder has broken, and I have seen that a spare cable costs €500 or more, depending on the distance.
Is it possible to make one?
I've read that you can make an impedance adapter using a ferrite thyroid and copper wire, but I don't know how the coil is made, does anyone know how it can be done?
Thank you very much in advance
Lisergio is offline
Old 08-01-2025 | 05:13 AM
Roelof's Avatar
Maybe this topic will help you. It is not only about the system itself but also about loop antenna's etc.
RCHourglass DIY Lap Timing (AKA Cano revised) - R/C Tech Forums
Roelof is offline
Old 08-02-2025 | 09:57 AM
The project is impressive, but it doesn't help me, the antenna is with amplifier, I'm looking for a way to make the original antenna of the AMB system. The track loop is not a problem, they are two cable lines joined by a resistance of 470ohm, this loop, is attached to the decoder with a coaxial cable, which has an impedance adapter made with a ferrite toroid... that is the cable I am looking for, I have tested with RF schemes of a 6:1 balum, but they have not worked for me.
thanks!!
Lisergio is offline
Old 11-07-2025 | 05:27 AM
thanks!!
Hello, yes I producing cables for my Lap timing decoders, they are 100% compatible with AMB/Mylaps. You need high quality 75 Ohm coaxial cable, high quality 75 Ohm BNC connector (not 50 Ohm!) and you must make balun. Balun I'm winding with 0.4mm cable 8:20 turns. After winding allways need performs tests. Not all baluns works from first time, sometimes it's need cut cable end and make new balun, as when you cover all with epoxy resin (for water and dust proof ) balun slightly changes their parameters and not reaches needed parameters (too low hits). I have referent cable - and all produced new cables/baluns compare with this cable.
Sorry for my English. Andrius
andrius is offline
