iCharger X6 "Input over voltage"?
I bought this charger for the size and features, and received it yesterday. However, after just over a minute of charging a battery, I get the "error Input over voltage 0201". I found that topic posted here, but there was never a resolution, or follow up on how to fix the problem. Has anyone run across this problem, and found a solution?
Did you get a voltmeter and actually did check the power source? What power source are you using?
If you are sure the power source is not going beyond the limit then there is something wrong with the charger internally
It was tried on two different 12 volt server psu, well below the 32 volt input limit. I'll try using a lead acid battery for power later today, but as you say, I suspect that it's damaged, and will be returned.
Final resolution, sending it back for a refund. I had bought it through Amazon, but before I went through that I did leave a message through the seller's website about the problem, with no reply.
found this. Icharger X6 Input Voltage Issues. try hooking to car battery and see if it works? Show pic of your power supply. Bet that's your prob. Get a real dc power supply.
If you bought the charger from progressive then just email them and send it back to have it fixed. If not, I guess you could still email progressive to see if they repair chargers not bought from them, maybe for extra cost. Heard iCharger arent really fixing/responding when you email them about charger repairs.
