FlySky Noble NB4
#1231
Looking forward to your results. I've mentioned before that I have run out of range while using my antennaless RX and did want to try and measure my antenna RX to compare. Don't recall if I mentioned it a page or two ago or not but last I went out with my SkyRC GPS meter things didn't go well because the numbers didn't make sense. What I do know is that I drove my Savage Flux farther than I had any business driving it before I decided to drive it back to me. I was using my enchanced RX. I've mentioned that, at least on my Pro, I use 2way/2channel mode to achieve the best of both worlds in terms of latency and telemetry. Gotta have my telemetry.
#1232
Installed, set up sub trim / end points for steering and initially calibrated the ESC; braking only slowed it down and didn't actually stop it. It didn't brake aggressively as the stock RTR transmitter did. Drove great for what little I was able to drive before thunderstorms and lightening showed up. Didn't get a chance to check the range; hopefully tonight.
I changed the ESC brake strength to step 5 / 75%; seems bizarre that the default ESC Brake Strength was 37.5%, because the stock RTR SLT3 transmitter, the brake was very aggressive on my Typhon 6S on default setup 2 / 37.5%.
Update, brakes work great on step 5. Range test tonight.
#1234
looking for a radio for nitro buggy. I see there are different versions of this transmitter. which one should I get? I heard there were problems with the first batch of transmitters.
How can I tell which one is the latest model?
#1235
#1236
Be aware that the FGr4 receiver is very large and won't fit in some radio boxes. I've used the smaller FGr4S (internal antenna) and the smaller FGr4P (external antenna) for racing nitro buggy and haven't had any kind of range issues with either one.
#1238
I tried emailing to no avail, but does anyone know if they have, or planning on changing up the battery port to USB-C? This battery is my only thing left in my entire house that isn't lightning or C.
#1239
If Flysky had such plans, they probably would've introduced the C port with the Pro version of the NB4. I dare say there is zero plans for a C port in the NB4 line. I perfer USB C but how much of an issue is a Micro usb port? I leave the cable on my charge hub and it's a non issue.
#1240
Has anyone purchased a NON PRO Version of the NB4 lately? Can you confirm if they fixed the deadzone on the NON pro version as I have read some post on youtube that some users have not experienced this same deadzone that was brought up in the Youtube video review.
#1241
Also very good point, if they were, it woulda been on the pro
#1242
Mines about 6 months old running the 93 software still and I've never had the issue
#1243
Well that is why I am asking because that video from Razor RC shows it has a small deadzone in the steering, and some issue with the Steering EXPO setting not being linear. So I wanted to see if that was corrected as I have seen post on youtube that some Non Pro owners do no have this deadzone. So I am seeing mixed feedback.
#1245
700Likes
