New Spektrum DX5 Pro
#16
Nick, thank you for the information. I have a couple of other quick questions. Does the DX5 Pro come with both the small and large wheels, or just the small? Are the grips the same material as the DX5R (I liked those)? Lastly, have any changes been made to the battery door (does it still use 2 small screws)? Thanks!
#17
Yes, the 5 Pro will come with both large and small wheels (and the correct cams to use them). It will come with small, medium and new large grip (larger than used on the 6R). The battery door was not changed this go around. That will be a bigger change to go with a bigger platform update way in the future. Now a days everyone has a 1.5 wrench with them, so its not so horrible.
#18
#19
#20
Thanks for the info, sounds very good - especially all of the included accessories. How does the range compare between the SR2100 and SR2010? I may opt for a transmitter only version and buy a 2010 if there is a large difference in range (will be using it outdoors a lot). That reminds me, does the transmitter only version still include the accessories? Thanks!
#23
#25
I may pull the trigger on this one. Just a few questions though.... Can the preset Losi models be erased, or do you have to work around them? Also, does this unit have the same loose flap issue the DX6R has? I've read this unit is backwards compatible with DSM2 receivers; at what frame rates can these older receivers be bound at? And lastly, how does the screen size compare to the older, DX3R Pro?
#26
#27
19Likes
