do you feel safe at a track??
#61
any amperage of batteries recommended max C rate.
#62
20 amps is only 4 c if their 5000mah cells.so not over 5c rate
#67
ah, rebuildable wet acid batteries....
tow-motors an such... 1,000 pound battery and UP.... single 24 volt battery.. some 48 volt..
even hear of the Ma-bell wired telephone battery banks... massive
1,000 amps PLUS... some years ago...
that is HIGH AMP charging..
better to 'defined' your numbers.
#68
Personal Safety... its your responsibly
do you know all of the exits.. from memory.. with eyes covered..
IF NOT.. you are in danger..
first thing a fire does.. is cause you NOT TO SEE..... then not to breath.. so craw out of the building... using said MEMORY...
#70
Yep, taking a 4x4 Shortcourse Mod to the head of a kid. That would be my safe worry. People don't like it when you slam their buggies during practice also.
I'm running two iCharger 308's. Stock classes charge 30 amps, discharge 30 amps. Mod classes, charge 10 amps, and I don't discharge. Testing it out.
I only charge 1 battery at 30amp, at a time.
#73
#74
I was thinking about something that might be relevant here.
With an ever increasing number of people high current cycling has anyone noticed an increase of lipo fires?
