Losi 1/6th Audi R8 Supercar Development 6IX Platform
#91
Wow...nice fender mod. Talk to me about it. You seem to be a car genius. We clearly have the same taste Mr STARK......
Tell me how and what and ill have a go. P/M me if you don't want to say..
#92
wow looks good sir. Let me know how you did those fenders. Ill have a go myself.
We clearly share the same interest in cars and design .........Mr STARK
#93
Nice work. Looked at picture before and missed them.
#95
After installing the new GRP/wheel combination I knew the white GRP wheels needed painting or dipping matte black. I might do a white R8 body down the road which the GRP stock white wheels would look okay. I'm a visual guy and after installing the wider GRP wheels the car took on a completely different visual appearance allowing more wheel to fender clearance top to bottom allowing the visual eye to see through to the chassis and motor. The fender mod covers the extension of the wheels sticking out and almost looks like it came from the factory...which was the goal.
I wasn't sure how they were going to turn out and decided to first mount them temporarily with very thin two-sided airplane tape before mounting permanently to the body. The fenders are rubber in construction and came off a Toyota 1/10 scale hilux. If you look close you can also see a few subtle graphic mod's on the side air induction intakes and swoop graphic above the 6IX.
I have a 6th scale race driver for the cockpit...still working on a carbon racing seat to sit over the dynamite motor & dashboard steering wheel mold. Hope to get this finished up soon since the car hasn't been run yet. I also added a black line pin stripe to the rear quarter just above the fender and rear window to better define the factory body cut line ...the silver striping on the widows need to be redone there bubbling a bit.
Hard to see this vehicle perched on my desk everyday without a single run. After it's scheduled trade show appearance it's on the tarmac for some bashing!
#96
Fenders
What fenders are they from. I can't find any hilux fenders for sale. Can you point me in the right direction. Are they on eBay? How did you fix em on.
Thanks.
Thanks.
#98
I purchased them awhile ago for another car but they were to big but perfect for the R8... you can find them from this seller...
http://www.ebay.com/itm/New-Tamiya-R...IAAOSwF1dUUT9j
There mounted with airplane tape seal I'm going to use titanium screws in the mounting holes.
#99
Gluing new tires on old wheels
So I took the plunge and ordered a new set of wheels and tires, they do seem different than what came on there, a little harder maybe, or just me wishful thinking. I am waiting on the adaptors like a lot of you are but had a thought of ordering just the new stock tires and gluing them to the wheels. This hasn't been discussed yet, maybe because the tires are nearly $80 a set which is still pricey but since there is no alternative right now this is an option. Since I am super new to the on road RC scene is this a good option? Are there any big disadvantages to doing this? I'm sure you have to do a good job gluing since the speeds the car will hit a little out of balance could effect performance. Just look for some thoughts and advice.
Thanks,
Rick
Thanks,
Rick
#100
I, like the others are waiting for 1/5 adaptors to become avalilable.
#101
chaps. Any one clocked any speeds yet? What are you finding is the best pinion. Standard 21 or maybe a 16/17. Let me know
#102
What kind of axle does it use?
If it uses 8mm 1:8 scale axles, grind a flat spot on them, and you can use the FG style square hubs.
#103
What 1/5 tires and wheels would you use ?
I'm hesitant to buying this 1/6 because of the short tire life.
Also is it possible to fit two 4s lipo's in parallel to get a lot longer runtime ?
How big are the batt compartments. ?
#104
I'll see if my 4s batteries fit tonight. Comparment is bigger then it looks.
#105
Speeds.
Has any one any idea of speed yet on this car. Standard hearing on 6s?
Also try the 16/17 tooth pinion losi recommend for better acceleration.
Let me know if you get a result.
