Rody VS Racing Engines - Onroad Motors
#211
Because our engines work on self combustion the ignition timing is set by the combination of the glowplug number, nitro content and compression. By changing these numbers you can shift the ignition timing.
On short tracks you can take out an 0.1mm shim giving more bottom torque but less top RPM (and with that also the chance of blowing plugs when running too much rpm or going too lean on the needles)
On large tracks you can add an 0.1mm shim so the engine can run higher revs but it will loose a tiny bit bottom torque.
And with todays 0.15 and .25 shims you can even finetune in 0.05mm steps headplay.
Also the milage can be afected by these changes.
#213
Rody, is the HIPEX 21 2069 Strada Evo2 pipe different now than the 2069 HD Pipe. I recall that Collari raced the 2069 EVO2 yet his was anodized Grey, Is this where the HD comes in now?
Last edited by 1/8 IC Fan; 03-12-2019 at 04:55 AM. Reason: Added annodized Hipex pipe.
#214
Collari found his own supplier for the Hard Anodizing and Hipex uses a different supplier.
For me the outcome is the same in terms of performance, they just look different.
#216
So the one's you have seen on RCMag are the pipes from last year you see on the pictures.
The color should stay stable now, but at the end the reason for the Hard Coating is to make the material a little more stiff and easier to clean.
#218
You could just try and see how it works out.
#219
thanks rody, waiting for some decent weather here in the uk to try the GT car and had seen some GT motors going cheap but think i'll just use the vs02
now.how about manifold shortest possible or a bit longer offroad one.
will there be a vs euro spec r21?
thanks rick...
thanks rick...
#220
thanks rick...
thanks rick...
If you are going to use the VSR02 then I suggest to use the VS30L50 manifold.
For the new engines, we still need to sell some VSR03 engines before moving to something new.
#222
#223
hi rody could you help with a tuning problem on my vsr02 and os r2102 with
vs button fitted i have the same problem. feels like a lean bog but more in the midrange,this is worst coming out of the hairpin at end of the streigh
i managed to tune it out for the final but had rich bottom and top.at end of
15mins engine temp was low 90s with air temp around 18.engine ideled down
streigh away on pitstops and end of race.
the vsr02 is great in gt car whey more power than grip at the moment and the early clutch does not seem to be a problem.
#224
If you engines has a hard time to come out of the corner after the straight then this is for me a clutch coming in too early.
Seems in the final your engine was too rich overall and with these temperatures(90°C) the engine should be strong on bottom and mi-range. Unless the clutch comes in too early it will make the engine slow out of the corners.
Rody
151Likes
